Location of blowoff valve?
Old Dec 11, 2001 | 01:21 PM
Struggly's Avatar
There are two plastic valves that look like compressor bypass valves with hoses going into the airbox. What is the one that runs from the intake manifold to the airbox (this is the one that has only about 3" of hose between the airbox and the valve)? Does the car have 2 blowoff valves? That doesn't make too much sense but...these cares are not known for their conventionalism.
Clint Fralick
Struggly@hotmail.com
Old Dec 11, 2001 | 01:29 PM
JoeD's Avatar
one is the BOV, the other is the CRV.
Old Dec 11, 2001 | 02:05 PM
Struggly's Avatar
Yes, yes. But which is which? Is the one mounted closer to the airbox the blowoff valve or is the one mounted about a foot back of the airbox the blowoff valve?
Clint Fralick
Old Dec 11, 2001 | 03:34 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
The one closest to the airbox is the BOV.
Old Dec 11, 2001 | 04:32 PM
martini's Avatar
Bingo...the "upper" hose.
Old Dec 11, 2001 | 04:52 PM
1bad7's Avatar
hmmm... if u go with an aftermarket BOV can you just pull both the crv and blowoff valve out or do you have to keep the crv?
Old Dec 11, 2001 | 08:42 PM
Bucrx7's Avatar
You have to keep your CRV. The CRV bleeds excess boost from the secondary turbo until it reaches 4500rpm then it closes.
Tony S.
Old Dec 12, 2001 | 12:52 AM
Thats funny...the blow off valve on mine seems to be the lower hose...the one with the tiny 3" rubber piece to the airbox. It was definetly louder when I disconnected it. When I disconnected the top one off from the airbox, car still sounded the same. Are you sure MArtini?
Old Dec 12, 2001 | 12:56 AM
Dr Wankel's Avatar
Altitude SUCKS!!!
The hoses could have easily been switched at some point in time. It wont matter if the hose is going to the top hole or the one below it on the airbox. The BOV like I said previously is the valve that is closest to the airbox.
Old Dec 12, 2001 | 08:42 AM
GsrSol's Avatar
Z06 powered FD
Should be the bottom hose.
Old Dec 12, 2001 | 11:33 AM
maxpesce's Avatar
Ex fd *****
The BOV should be in the hose that comes from the center of the 'Y' pipe - The CRV comes up from near the second (rear) turbo
Old Dec 12, 2001 | 06:41 PM
luckly i didn't empty my trash
here's a pic
er link
https://www.rx7club.com/vforums/show...threadid=37209
Old Dec 15, 2001 | 02:02 PM
1bad7's Avatar
Thanks Tony S.
I was afraid that i might really screw something up.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Tem120
Sep 7, 2015 09:53 AM
