is engine really blown
Old Dec 30, 2004 | 09:45 AM
fcrx88's Avatar
rotary fiend
Ok i bought an 87 t2 with a blown motor. 80 psi on the front rotor 60 on the back. an im wondering what i can do to find out if its blown for sure or its just carbon buildup ( i wish) i wanna try the atf trick but im worried ill just be wastind my time. the guy i bought it from was driving and the motor just cut out he said. he thinks it was running lean. safc2 is installed but not tuned correctly. it cranks fine like it should and occasionally starts but runs rough and then dies. sound like a blown apex seal? thats the conclusion i have come to but was hoping you guys might have some good input? if the apex seal is blown i guess im gonna have to buy a jspec. id like to rebuild it myself but i dont feel confident enough to do it on my own. i dont suppose there any rotorheads in the md area who would like to help me? or any good rotary shops in the area with decent prices? around the price of a jspec? thanks for the help.
Old Dec 30, 2004 | 09:52 AM
Froggmann's Avatar
Ring ading ading
How many miles on the motor? On the rear rotor does it have three even 60PSI readings or just one?
Old Dec 30, 2004 | 09:53 AM
fcrx88's Avatar
rotary fiend
93,000 on car and it didnt have an even 60 psi all around. it was the highest number.
Old Dec 30, 2004 | 10:01 AM
therotaryrocket's Avatar
PIMP
sounds like it could be an apex seal stuck in it's groove from carbon, or more likely a collapsed apex seal spring. well atleast its on the rear rotor so the front won't even have to come out unless you just feel like you want to rebuild the whole thing. Im not sure. gl
Old Dec 30, 2004 | 10:14 AM
fcrx88's Avatar
rotary fiend
well if i have to pull the motor apart im going to rebuild the whole thing. i want to try the atf trick but dont want to waste a set of spark plugs if its not going to do anything.
Old Dec 30, 2004 | 11:00 AM
fcrx88's Avatar
rotary fiend
bump
Old Dec 30, 2004 | 11:59 AM
Parastie's Avatar
Mountain Rotary Mod
Waste a set of sparklpugs? You're not talking about a $250 investment, it's only a little more then $20.
Old Dec 30, 2004 | 12:02 PM
Parastie's Avatar
Mountain Rotary Mod
A 20psi different is quite a lot. While it could be carbon buildup on an apex seal, it kind of doubt it. You can use the water treatment to attept to loosen the carbon. There is a right up over at www.rotaryresurrection.com .
Old Dec 30, 2004 | 12:14 PM
fcrx88's Avatar
rotary fiend
i know spark plugs arent that expensive there like 8 bucks a peice or somethin like that. i figure its the apex seal but i figured id get some advice from you guys.
Old Dec 30, 2004 | 12:32 PM
Parastie's Avatar
Mountain Rotary Mod
If you're feeling up to it, you can pull the exhaust off, rotate the engine by hand and examine the apex seals.
While you're at it, you can also use a small thin screw driver to push on the apex seals to make sure they're moving and not stuck.
Old Dec 30, 2004 | 12:37 PM
fcrx88's Avatar
rotary fiend
well id have to pull the turbo off as well wouldnt i? i heard something like that but threw the spark plug holes. i may be mistaken though.
Old Dec 30, 2004 | 01:00 PM
Rx7MPGUY84's Avatar
Rpm abuser
you cant see crap through the spark plug hole. mines got 2 broken apex seals and it still started. Id get it rebuild anyways.
Old Dec 31, 2004 | 10:08 AM
fcrx88's Avatar
rotary fiend
well it looks like im gonna be pulling the motor apart soon soon hopefully i wont need new housings. also i have the haynes manual. is there anything they missed in there? it seems pretty in depth but i heard someone mention that they missed some stuff.
Old Dec 31, 2004 | 12:06 PM
fcrx88's Avatar
rotary fiend
bump
Old Dec 31, 2004 | 12:28 PM
Kingofl337's Avatar
Letting the Smoke Out!
well just keep us posted on the rebuild. Hope for good housings :-p
Old Dec 31, 2004 | 12:40 PM
RotaryEvolution's Avatar
Sharp Claws
if you don't want to risk a set of spark plugs then i don't think a rotary is the car for you.
Old Dec 31, 2004 | 12:59 PM
Andrew.'s Avatar
The end of an era
^WORD. Just do the freaking water trick off rotary resurrection's website it will take off most of the carbon and possibly fix it.
Old Dec 31, 2004 | 01:22 PM
fcrx88's Avatar
rotary fiend
you guys take **** to literally its not like this is my first seven its actually my third. ive already done a t2 conversion so get off my back. i was just saying i didnt want to waste a set of plugs for somethin i dont think will do much good. just by the description the previous owner gave me i think an apex seal went bye bye. so i guess the motor is coming out in a week or two when i get a chance. so ill let you guys know whats up when i pull it apart.
Old Dec 31, 2004 | 02:07 PM
F1blueRx7's Avatar
Couldn't stay away
If it were me doing a rebuild, I would throw the haynes in the trash, get an FSM and the atkins rebuild video. The haynes is ok for general reference, but get the rebuild video it really covers all your bases.
Old Dec 31, 2004 | 03:01 PM
Parastie's Avatar
Mountain Rotary Mod
You can do this, but it's be much harder. You need to get to the lower spark plug hole, as the top one is too small. Also, you will need a small mirror so you can look into the hole, and you'd still only see a small fraction of the apex seal.
The exhaust port is the best way to see.
Old Dec 31, 2004 | 05:09 PM
fcrx88's Avatar
rotary fiend
ok well i appreciate it i think im gonna pull this motor out and if i find a good jspec ill throw that in and rebuild this one for fun so i dont have to stress about it now. maybe go with a big port job and that good stuff.
The Shaolin
Sep 14, 2015 07:50 PM
cdn
14
Sep 10, 2015 06:23 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
