Is my motor fried
Old Dec 11, 2001 | 08:03 AM
Flinstone Power
Question Is my motor fried
I bought a 87 GXL with 181,467 miles. Ya I know it has a lot of miles for a rotary but it runs great. The only thing is it smokes(white) for a couple min. on cold starts but then runs great. I was told last night my motor seen its last days. I just cannot see how becuz it runs great(but has a slight miss). If my motor is fried I am just goin to drive it until it blows but then I am goin to put a entire T2 drive train in it so any help or leads would be appriecated. Thanks for the help. The turbo motor I plan on putting in this summer will be street ported, t04b, front mount IC, 680cc primary 720cc sec and a rewired high output fuel pump. Does this right? I also heard there is a trick I can do so I dont have to switch the computorsd. Well thanks Dave
Old Dec 11, 2001 | 08:18 AM
SaabGuy's Avatar
Look between your housings.....
More specifically, on the spark plug side of the motor, look at the seals between the aluminum and steel housings. Take a close look everywhere. If there is gooie stuff or oil oozing out, changes are you have blown oil seals. I have heard that this will not affect engine performance, but will cause the engine to burn or lose oil. So I guess your car could run a couple thousand miles more if this is the problem. I think there may also be some mechanic in a can for the oil seals, but I havent heard much about it.
doritoloco
Sep 5, 2015 12:41 PM
