new rear end gears??
Old Dec 27, 2004 | 02:19 PM
Whitesmoke's Avatar
3 cars infront of you
I did a search and couldnt find anything about this if its out there im sorry i missed it.
is there an after market company that makes 3.73s or some sort of shorter gear for a turbo rear end? because of my cars set up its not very streetable with 4.11s anymore and i would like a lower ratio gear. any help is much apreciated
TIA
Old Dec 27, 2004 | 02:24 PM
Turbonut's Avatar
Just an FYI-A lower ratio gear would be > 4.1 eg 4.3 not a lower number. Check Mazdatrix, Racing Beat. Lot's $$$$$, then it needs to be set up in diff.
Old Dec 27, 2004 | 02:31 PM
Icemark's Avatar
3.909 is the lowest I have ever seen for a FC or FD.
If this is some alternative engine, then you may wish to post in other engine conversions or on some of the V8 RX-7 boards.
Old Dec 27, 2004 | 02:42 PM
Whitesmoke's Avatar
ok thanks guys. it is a v8 car ill look around on some of those sites i just checked here first because of the mass number of members i figured i had a better shot of someone knowing
Old Dec 27, 2004 | 04:08 PM
IaMtHeRuThLeSs1's Avatar
I'm awesome!
go to www.torquecentral.com
btw a lot of guys are using ford 8" rear ends. Go there and ask them about it, they'll gladly help.
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
