Clutch pedal question?
Old Dec 25, 2004 | 03:22 PM
jm93rx7's Avatar
Committee Member #3
I was driving home last night and i started to loose pedal pressure in my clutch pedal or it wouldnt come all the way up. Im thinking its the clutch master cylinder. Any suggestions.?
I have an 88 10th AE .
Old Dec 25, 2004 | 03:25 PM
gonzz's Avatar
I just changed my clutch master for the same reason.
Old Dec 25, 2004 | 03:33 PM
jm93rx7's Avatar
Committee Member #3
Did it solve your problem?
Was it hard to do?
Old Dec 25, 2004 | 04:01 PM
rodney87's Avatar
Did you try checking the slave for leaks?changing the clutch master is really easy, you wont have any problem with it.
Old Dec 25, 2004 | 04:17 PM
jm93rx7's Avatar
Committee Member #3
Is there any bleeding involved? Or anything special i need to look out for?
Yes i check the slave cylinder and it has no leaks but i might change it just to be safe . I was looking at the clutch master cylinder resevoir and the fluid is really dark.
Old Dec 25, 2004 | 04:26 PM
Modified 7's Avatar
yea its probebly bleeding. My freinds fc leaks and now his clutch pedal is all the way to the floor and wont come up
Old Dec 25, 2004 | 04:36 PM
spot_skater's Avatar
The Cause of Death
did you check the clutch mc fluid level?
happened to me once and i just needed some fluid
Old Dec 25, 2004 | 04:40 PM
jm93rx7's Avatar
Committee Member #3
The fluid level was at full but the fluid is really dark.
When i change the clutch master cylinder do i have to bleed the system?
Old Dec 25, 2004 | 04:53 PM
felixwankel88's Avatar
i would drain the fluid, Put new fluid in, then bleed it, before you replace any parts... that solved my prob somwhat like yours
Old Dec 25, 2004 | 04:55 PM
jm93rx7's Avatar
Committee Member #3
How do you bleed the clutch master cylinder
Old Dec 25, 2004 | 05:08 PM
there is a little bleeder valve on the thingy on the metal thing that goes to the tranny ill try find u a pic
Old Dec 25, 2004 | 05:20 PM
gxlbiscuit's Avatar
DONT FEED THE NOOBS
three master cylinders later (original , two rebuilt)....... check to see if your fluid has and sparkles.. if it does new mastercylinder time. and like they said check for leaks new stainles steel clutch hose is only 20 bucks:-)
Old Dec 25, 2004 | 05:30 PM
jm93rx7's Avatar
Committee Member #3
well i guess ill just go ahead and get a new one. It looks pretty simple to put in and the local autoparts store has it for 60 to 70 dollars . I just need to know how to bleed it. What is the process ?
Old Dec 25, 2004 | 09:12 PM
sent u a pm
Old Dec 25, 2004 | 10:07 PM
RotaryEvolution's Avatar
Sharp Claws
you guys should be changing your brake and clutch fluids regularly, at least once every other year. meaning draining the reservoirs and adding new fluid and completely flushing the systems until clean fluid comes out. vacuum bleeding is the safest method if you can get your hands on a vacuum pump bleeding kit, it will not damage the piston seals.
Project88Turbo
Aug 29, 2015 02:23 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
