XS T04S questions????
Old Dec 24, 2004 | 05:07 AM
what times in the 1/4 mile can i expect with a T04S kit from XS? my mods consist of a 3-row greddy i/c, apexi pfc, 1600cc injectors, nippondenso fuel pump and a greddy elbow with type-s BOV. also, this question is kinda dumb but does the XS T04S kit make a good sound as well. i heard the HKS T04R kit makes a great whining noise and that is what i like to hear. so any T04S owners please throw me your 2 cents. thanks,
- Mike
Old Dec 24, 2004 | 05:17 AM
LT1-7's Avatar
John
We ran a trap speed of 125mph on our TO4S FD. That's good for 10's with good traction
Old Dec 24, 2004 | 08:23 AM
wow! thats really good. what else do you have on that rx-7?
- Mike
Old Dec 24, 2004 | 09:11 AM
shawnk's Avatar
Perpetual Rebuilder
Low 12's is easy...high 11's doable for most. 10's obviously possible but I dont see my setup getting there anytime soon.
Plus I dont plan on running the 1/4 mile very much so that might make it hard to get a 1/4 time.
Old Dec 24, 2004 | 12:39 PM
modrx7's Avatar
I haven't heard the best things about the XS kits...
Old Dec 24, 2004 | 12:54 PM
Wargasm's Avatar
Weird Cat Man
XS Engineering and XS Power are not the same thing right?
My T04S from XS Engineering has always worked perfectly.
Old Dec 24, 2004 | 01:32 PM
wargasm, im looking into a T04S kit from XS engineering. i want to make good 1/4 mile times and about 400 hp to the wheels. do you like your kit and do you get around the that number?
- Mike
Old Dec 24, 2004 | 03:35 PM
r1dreamer's Avatar
hows it going..alright i have a xs engineering t04e, adn i want to upgrade to the xs t04s. do you know if i can bolt that turbo right up to the to4e manifold? also what are the specs on your turbo if you dont mind?
thanks
brandon
Old Dec 24, 2004 | 03:51 PM
dubulup's Avatar
development
T04S
.70 A/R compressor 60-1 wheel (or 62-1) I think??
1.00 A/R turbine.
Old Dec 24, 2004 | 03:52 PM
dubulup's Avatar
development
- Mike
he makes something like 405rwhp @ 14psi
Old Dec 24, 2004 | 04:29 PM
LT1-7's Avatar
John
we made 461rwhp at 18psi and cutting redline due to fuel system problems
Old Dec 24, 2004 | 07:17 PM
Infini IV's Avatar
Microtech Tuning!
They are totally different!
XS Power "T04S" turbo's are not anywhere near a real T04S (60-1 wheel with T04S comp. cover).
Old Dec 24, 2004 | 08:14 PM
the_glass_man's Avatar
Will u do me a kindness?
thanks
brandon
It uses the same exact exhaust manifold so I don't see why you would have a problem. The dp might be slightly different, but I'm not sure.
Old Dec 25, 2004 | 12:36 PM
Wargasm's Avatar
Weird Cat Man
- Mike
I love this turbo. I do not race 1/4 mile, so I don't have an exact time for ya... I can tell you that it is ridiculously fast on the street.
I have some info about my dynos and mods and stuff here:
Dyno... newest at the bottom running 14 psi made 405 rwhp and 331 rwtq. I run around 15-16 psi on the street normally.
http://www.zeroglabs.com/rx7/dynoresults.htm
Mods list:
http://www.zeroglabs.com/rx7/mods.htm
Turbo kit pics:
http://www.zeroglabs.com/rx7/newturbo.htm
Old Dec 25, 2004 | 12:38 PM
Wargasm's Avatar
Weird Cat Man
thanks
brandon
I am not sure if it bolts up or not... My specs are 60-1 wheel in a T04S cover (this is the 4 inch inlet) with a P trim turbine in a 1.00 A/R divided housing.
Old Dec 25, 2004 | 07:45 PM
manatecu's Avatar
My XS T04S kit fell apart.
Turbo lost an oil seal and inducer blades were rubbing on the front cover. Manifold developed a crack about 3mm long, front turbo. Cross over pipe to intercooler rusted its milled steel, Down pipe split at the bottom at the flange and weld broke at the o2 sensor. The HKS wastegate is good but I just had to put a new gasket in. I have had no problems from the blow off vavle.
I can not recommend the kit.
The turbo has potential but I now run a turbo with a t04s inducer gt35r exducer.
Good luck
Chris
Old Dec 25, 2004 | 08:34 PM
modrx7's Avatar
yep... crap
Old Dec 26, 2004 | 04:36 AM
thanks for all your information wargasm, it really helps.
- Mike
Old Dec 26, 2004 | 04:37 AM
- Mike
Old Dec 26, 2004 | 04:38 AM
- Mike
Old Dec 26, 2004 | 04:42 AM
oops.
Old Dec 26, 2004 | 05:14 PM
manatecu's Avatar
What I forgot to mention in my rush the other day was the excellent customer service that XS provided to me. This may change your mind.
They took 3 months to rip apart the turbo to tell me the oil seal was blown and the inducer blades were shot. They also said a bearing could be replaced. They then refused to rebuild it and asked if I wanted to pay $850 for a new XS spec T04s turbo with a 2 month delay getting to me. Granted I only put about 4k on the one that blew.
As for the manifold they said it was my fault. They said I did not have adequate cooling in the engine. Anyone wanna explain that one to me.
End result 4 months of downtime over $200 in shipping bills and a turbo in about 30 pieces in a box. Not only that but for some reason they painted my manifold orange.
My downpipe was repaired by a local welder that charged me $50 to fix the holes and several problem areas. The pipe is milled steel (cheap) so it will probably be trash in a few years.
I hope XS reads this because their customer service is right up there with Enron. Thanks for first rate - 5th world quality.
Chris
Old Dec 27, 2004 | 09:32 AM
dubulup's Avatar
development
30 pieces? I don't remember seeing 30 pieces when I took my turbo apart
Old Dec 27, 2004 | 11:37 AM
Jason's Avatar
The one
Chris
Chris,
What turbo did you end up going with?
Jason
Old Dec 27, 2004 | 08:59 PM
manatecu's Avatar
Perhaps not major pieces but if you count bolts its about 30 - the point is they took the entire thing apart.
I went with a "Blowzilla" from cheap turbo.com - its a T04s front side its a gt35r hot side, non BB. Manifold was a custom SS made locally, downpipe was created at a local muffler shop with v clamps. Wastegate and blow off valve are the HKS that came with my XS kit.
