Energy Suspension endlinks - 86-88 on a s5?
Old Dec 23, 2004 | 05:02 PM
krazykoncepts's Avatar
I have purchased a energy suspension master kit, and drive a 90 gxl. I was told this was the only kit available for the second gen and all parts numbers are the same for the 86-91. However upon opening the kit my endlink instructions say there for the 86-88 rx. Does anyone know if there are some for the s5's? or what i am supposed to do?
Old Dec 23, 2004 | 05:33 PM
sunshine's Avatar
the S5 links are shitty plastic and are one unit. The S4 units have the bushing that are replaceble. If you want to upgrade to the S4 links, then you will need the S4 control arms, which are also an upgrade because of the replacable ball joints.
As far as I know, there are no replacements for the S5 links.
-a
Old Dec 23, 2004 | 05:53 PM
inflatablepets's Avatar
I have a set of S5 links if you are interested. P.M. me and we'll talk. BTW Dealer cost on them is like $90 each. I don't know any other company that makes them. BTW I do'nt want 90 each for them or anything like that.
HYPER-FLEX SYSTEM Complete Master Kit: constists of the following parts: Front & rear control arm bushings, front 24mm & rear 14 mm sway bar frame bushings bushings, ball joint and tie rod end boots.
Includes the 9-8134 endlinks, that will not fit the 89-91.
Old Dec 23, 2004 | 06:36 PM
Tierce's Avatar
time to go with aftermarket sway bar and new endlinks...
Old Dec 23, 2004 | 10:32 PM
Well nothing is wrong with my endlinks. I was just replacing them since there old and obviously not as good.
Do the s4 control arm have any other benefits? other then i can use the energy suspension bushings in the endlinks, and that the replacable ball joings???
Old Dec 24, 2004 | 12:17 AM
No, not really. If you wanna sell the S4 links then let me know.
Old Dec 24, 2004 | 12:21 AM
i have s5 links with s4 bushing from ES. You want the bushings? Make me a offer
Old Dec 24, 2004 | 11:04 AM
If it can wait till after the holidays then I'll be interested.
Old Dec 24, 2004 | 11:32 AM
NoPistns's Avatar
The replaceable balljoints are a huge reason to go with the S4 control arms! A ruptured balljoint grease boot resulted in buying a $400 control arm!
Postman09
Sep 29, 2015 11:23 AM
