still smokin sometimes!
Old Dec 10, 2001 | 03:20 PM
gamble302's Avatar
roadkill hats rock
i dont know why, but when i really get on it, my car smokes. lots of white smoke through the exhaust, not perfect white, but def a light color. i just got the car in september, and havent really ragged on it at all because when i do it smokes bad. i know the previous owner did the mmo treatment about a month before i got it, maybe its got some residue in the presilencers or something still(rb street port exhaust). it doesnt smoke at all under normal driving, it runs just about perfect except for the smoking. any ideas?
Old Dec 10, 2001 | 03:47 PM
Felix Wankel's Avatar
Super Newbie
That used to br Mr Rose's car right? Doesn't that thing have about 175k on it? The corner seals may be getting weak. My car smoked like that, and it only had 120k when it started doing it.
Old Dec 10, 2001 | 03:48 PM
REVHED's Avatar
Hunting Skylines
Does it smoke mainly when you let off the throttle at high revs? If it does it's the oil control o-rings. It's a fairly common problem for rotary's with a bit of mileage. Probably nothing to worry about yet but it will keep getting worse and you'll find yourself topping up the oil constantly. Another posibility is that you could be getting coolant in the combustion chamber. What does the smoke smell like? Are you loosing any coolant?
Old Dec 10, 2001 | 03:50 PM
Super Newbie
Thats what I meant. I need to stop posting right after I wake up
Old Dec 10, 2001 | 03:55 PM
gamble302's Avatar
roadkill hats rock
yeah it was mr roses car, and yeah 175k miles on it. never smelled it, and yeah it only does it when i let off the throttle. im not losing any coolant at all, and the oil isnt really all that bad. i'll double check all that before i go of to work though.
thanks
gamble
Old Dec 11, 2001 | 04:20 AM
REVHED's Avatar
Hunting Skylines
Yep, it's the the o-rings. Just drive it till it uses more oil than fuel than pull the motor out for a rebuild and some porting. Can you say bridge-port.
Old Dec 11, 2001 | 09:36 AM
gamble302's Avatar
roadkill hats rock
mmmm bridge port...... how hard is it to do it yourself, ive got just about every tool i would need its just about gettin down to it i guess
jrs10
May 19, 2005 09:53 PM
