Will this Header work on My Deuce?
Old Dec 19, 2004 | 11:04 AM
Hullie's Avatar
My Deuce Coupe
Will this Header work on my 4-Port 13B 74 RX2? Someone just sent me an e-mail telling me it wouldn't work.
click here..http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEBI%3AIT
Old Dec 19, 2004 | 11:48 AM
d0 Luck's Avatar
raysspl.com
as long as the bolts in the flange line up w/ the block it willl work.
Old Dec 19, 2004 | 11:59 AM
Crit's Avatar
No distributor? No thanks
Yeah, the bolt holes are in the right spot, it's just a matter of what your exhaust looks like now. Most deuces nowadays have RX-7 headers by now, where the primaries are longer, so the output flange is back closer to the firewall. If your current exhaust has the flange in the OEM spot, then it'll work just fine.
Old Dec 19, 2004 | 01:32 PM
Matt22's Avatar
Fear The RE
so what yourt saying is depending on what motor you have in your duece, makes a difference in what header you run? IE i got the twin dizzy so i would need a regular rx2 header, where as if i was runing a first gen 12a i could use a rx7 header? same with a second gen block and a 2nd gen header? with considering clearance issues. thanks matt22
Matt22's Avatar
Fear The RE
I guess i should have jsut asked you to futher explain what you mean. thanks crit. Matt22
Old Dec 19, 2004 | 03:52 PM
Jeff20B's Avatar
Lapping = Fapping
I don't think Racing Beat made that header. Only the flange is from Racing Beat.
