I need help......The power windows will not roll up but they will roll down.
Old Dec 9, 2001 | 05:17 PM
NO AUTHORITY RACING's Avatar
i took the drivers side window switch box apart found one of the plastic tabs fell off if any one knows how it works or can at least tell me a way to raise my window for now???????//
Thanks, James
Old Dec 9, 2001 | 05:46 PM
Want2race's Avatar
Bigger and better things
I had that problem... I just unseated and re seated the connection and it worked
Old Dec 9, 2001 | 05:53 PM
which connection?
Want to race--- I pulled the box out of the door panel and picked it up there was like 5-6 connections solderd to the bottem but i think its the plastic clip the you use to put the window up--- The passanger side and driver side lost resistance.
Old Dec 9, 2001 | 08:24 PM
Magnificent 7's Avatar
I had this happen to me twice. The switch on the driver's door would lower the passenger window, but when you pulled up on the switch to raise the window, there was no resistance on the switch. I'm not talking about electrical resistance, I'm talking about physical resistance, you know that springy feeling that returns the switch to its neutral position. I was able to disassemble the switch and repair a little broken actuator lever inside with super glue (no electrical work required). I was able to operate the pass. window with the pass. door switch. The next time it broke about 18 - 24 months later, (the glue finally gave way) I had warranty replace it.
Old Dec 10, 2001 | 10:07 AM
yup, bingo
Mag 7, thank you that is exactly what happened. and when i took it apart the switch was broken. ill try yo glue it back together first.
Old Dec 10, 2001 | 11:58 AM
DK's Avatar
DK
40k worth of fail
You should just put a black plastic trash bag in that **** and you'll have some mAd tYtE wInDoW tInT, yO!
