Power FC simple pfc question
Old Dec 15, 2004 | 06:21 PM
JebenKurac's Avatar
simple pfc question
my 93 is still pretty stock and im wondering if i swap in a power fc will i need a commander to set some things on the initial start up? or if i swap it in and turn the car on will it run the same as stock and not need tuning until i start adding on performance parts...
Old Dec 15, 2004 | 08:01 PM
cewrx7r1's Avatar
Eye In The Sky
You do not need the commander but YOU SHOULD GET ONE ASAP as it can be used for fine tuning for idle and cruise control for better mileage and lower emissions.
Old Dec 16, 2004 | 09:20 AM
TailHappy's Avatar
Addicted to Track
I agree with Chuck on getting a commander. I wouldn't trade mine for anything.
However, if your car's still relatively stock, you should be able to swap in the PFC and drive off without any problems. Just be sure to let it learn the idle first. I put mine in while my car had very few mods on it and was thrilled with how much better the car ran. However, IIRC the PFC has richer maps than the stock ECU, so your mileage and plugs might suffer a little.
One other thing. I'm assuming you're buying a new PFC. If you're getting it used, then you'll need to make sure it still has the stock settings still into it.
Old Dec 16, 2004 | 08:25 PM
JebenKurac's Avatar
thanks for the input
_Tones_
May 25, 2021 05:37 AM
24seven_dada
20
Nov 10, 2018 12:03 PM
msilvia
15
Sep 11, 2015 12:13 PM
Nosferatu
Sep 5, 2015 02:13 PM
