Was this hose job done right? Pic. inside.
Old Dec 9, 2001 | 02:32 PM
Had a hose job done at Rotary Power...my question is, whether it was done right... I was comparing in to the sticker attached on the hood of the car...seems kinda different.
First of all, the check valve leading to the pressure tank seems switched around....arrow points away from tank. Second, the hoses from the pressure tank seem switched too...meaning the hose thats supposed to go to the y-pipe area goes down to a solenoid instead and vice versa shown on the picture down below. would this affect my boost patterns?
Old Dec 9, 2001 | 02:36 PM
GsrSol's Avatar
Z06 powered FD
I think the hose is in the right place, can't really tell. According to mine, the check valve is backwards.
See if you can find it on the downloadable version:
http://www.rx7.org/Robinette/hoses.htm
Old Dec 9, 2001 | 02:46 PM
Here is a closeup of the y-pipe section....the hoses down here seem switched too. Am I reading the diagram right?
Old Dec 9, 2001 | 02:59 PM
GsrSol's Avatar
Z06 powered FD
Yep, thats what I got but the check valve is backwards.
Old Dec 9, 2001 | 03:27 PM
hmmm...I wonder if this is one of the few problems to my boost patterns...bascially can't hold boost when 2nd turbo kicks in...thanks alot GSROL
Old Dec 9, 2001 | 04:09 PM
GsrSol's Avatar
Z06 powered FD
That maybe one of the problems.
I only hold 7psi on my second turbo and have narrowed it down to the y-pipe.
