is it safe to sand blast rotors???
Old Dec 13, 2004 | 10:55 PM
MOBEONER's Avatar
It's finally reliable
my rotors are dirty as hell,but i am scared that sand blastinf might damage something...
Old Dec 13, 2004 | 10:58 PM
I wish I was driving!
Engine rotors? No. Not even close.
Brake rotors? The centre hub would be fine to sandblast.
Again, no to the engine rotors.
casio's Avatar
casio isn't here.
any speck of sand not removed is bad news as far as i know. buy some heavy duty cleaner and a metal brush. and some rubber gloves that go to your elbow; chemicals eat your skin. oh, and have fun!
Old Dec 14, 2004 | 05:51 PM
Bluetwo's Avatar
Monkeys!
Yeah I thought you meant brake rotors too....
some people actually rough em up a little before they hit the track. At least that what that one guy said on Speed that one time.
Old Dec 14, 2004 | 07:40 PM
HAILERS's Avatar
HAILERS
If I remember right, the FSM says:
1. Remove the carbon from the rotor with a carbon remover or emery paper. CAUTION (a), Do not use emery paper on the groove of the apex seal or side seal. (b) Take care not to damage the soft material coating on the side surfaces.
2. Remove the carbon in each groove.
3. Wash the rotor with a cleaning solution.
That's from the online FSM I just looked at.......online. Free. Cheap. Download two for the price of one.
Old Dec 14, 2004 | 09:51 PM
Registered Abuser
Call me crazy if you must but all of the old head rotary guys I've spoken to usually submerge their rotors in gasoline overnight before cleaning. I've done it on one motor and it seemed to make cleaning a little easier but i've only done it once and i've only ever rebuilt 3 motors so i dont think its enough to swear by. Anyone have a legit reason not to do that they can support with proof or reasonable certainty?
Old Dec 14, 2004 | 09:55 PM
Sand blasting removes material that is required for tolerances at the side seals, corner seals, and apex seals. After sandblasting, there would be no way to get the seals to fit with spec.
Old Dec 14, 2004 | 10:08 PM
inflatablepets's Avatar
There will be a small abount of the blasting media left behind. It can come off and ruin the engine when you run it. The same is true for sandblasting spark plugs.
Old Dec 15, 2004 | 11:56 AM
Snrub's Avatar
As for doing brake rotors, I sand blasting tends to leave things pitted and not a smooth, even surface. I'm certainly no expert on the process, but I'm not sure that would be a good idea.
Old Dec 15, 2004 | 01:22 PM
brakar's Avatar
I used a dremle and a soft wire wheel to clean my rotors. You have to be very carefull around the seal seats thou. Work realy well thou, got all the carbon off.
Old Dec 15, 2004 | 02:38 PM
ajsuper7's Avatar
Nothin But a G Thang
dump them in castorl superclean...that should alteast loosen the carbon to come off easily with a little elbow grease. superclean did wonders to all the parts i needed to clean and its cheap.
Old Dec 15, 2004 | 03:14 PM
Mr. Gadget's Avatar
Older than Dirt
this is so easy I cant believe it.
Buy - one gallon of simple green
submurge a rotor for about three days
rinse off
oil to prevent rust
Old Dec 15, 2004 | 04:50 PM
Falcoms's Avatar
kill it with BOOMSTICK!
rinse off
oil to prevent rust
I was hoping somebody would get to simple green soon...Great degreaser, and safe for the rotor and your hands
Old Dec 15, 2004 | 06:01 PM
Safe for rotor, safe for hands.... not safe for rotor bearings. Neither is Castrol.
Old Dec 15, 2004 | 06:03 PM
No, not smooth. That's why I said to use it on the center hub, and not on the friction surface. You tape off the friction surface with lots of layers of tape.
Snook
Oct 4, 2015 08:47 PM
risingsunroof82
22
Sep 22, 2015 01:20 PM
tiger18
Sep 3, 2015 08:27 PM
