No power to radio. Help!!!
Old Dec 13, 2004 | 12:52 PM
reeducator's Avatar
Question No power to radio. Help!!!
Ok after having my radio stolen out of my car........im getting no power to the radio. I have replaced and tested all of the fuses and found them fine. SO im thinking its a short somewheres. What are my alternatives? Do i run power from the battery? If so how do I do it. I miss my tunes!! Help
Old Dec 13, 2004 | 01:19 PM
poorboyracing's Avatar
Powered By Craigslist!
If the radio fuse is fine, test the actual wires. if it still doesnt work bring it to a professional audio shop.
Old Dec 13, 2004 | 02:04 PM
jeff48's Avatar
Rotorally Challenged
Need additional info----
What system are you running in the car. If it is the bose, see the sticky above
Old Dec 13, 2004 | 09:12 PM
Modified 7's Avatar
my radio was stolen out of my car too and i replaced it with a 100 dollar jvc deck and it wont work at all. I checked my fuse's=fine, made a ground for it=fine. Im thinking its my ecu because my idoit lights or clock or cruise control work
Old Dec 13, 2004 | 10:36 PM
reeducator's Avatar
Everything looks fine
The lights are on fine..............System i got to replace is sony.......like the one that was stolen. Got sony xplod amp and 4 speakers to replace...........just cant get any power to the hed unit.
Old Dec 13, 2004 | 11:56 PM
Dan_s_young's Avatar
Turbo widebody FB
use a test light... find your constant 12v and then find your ignition wire... easyier done then said =-)
Old Dec 15, 2004 | 02:59 PM
Iggy76's Avatar
Did you test the wires or just plug the harness into the new radio? There is no guarentee that the harnesses are the same... test the wires to be sure that you are getting power to the right wires and make sure you are using the correct harness for the radio.
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
