Vacuum Leak. Help Please
Old Dec 8, 2001 | 03:48 PM
Zoomspeed's Avatar
I'm getting some low Vacuum. 14 inHG @ 500RPM to be exact. Also, when coming to stops with ym clutch pressed in my RPM likes to hang around 1200-1500 RPM for a few seconds. Is this becasue of the vacuum leak?
Where should I look for leaks?
One more thing; Isn't 500 RPM low for idle?
Thanks
Old Dec 8, 2001 | 04:03 PM
mmaragos's Avatar
Should be closer to 720 rpm for idle.
Increasing idle should increase your vacuum. 14" Hg isn't too bad, especially for 500 rpm.
Old Dec 8, 2001 | 05:44 PM
Zoomspeed's Avatar
How do I adjust the idle?
Old Dec 8, 2001 | 09:07 PM
mmaragos's Avatar
go here for some good info...
http://www.scuderiaciriani.com/rx7/idle_adjustment.html
If you don't have a shop manual...this may help...
http://www.scuderiaciriani.com/rx7/shop_manual.html
Your G-Force re-mapped ECU may have some hand in the 1200-1500 intermittent RPM issue...maybe???
Old Dec 8, 2001 | 09:48 PM
Zoomspeed's Avatar
The 1200 - 1500 RPM thing was there when I had the stock ECU. I noticed it is alot more extreme when there an electric load. like when I have the AC and the fans on.
ls1swap
Jun 3, 2024 03:25 PM
