Look What I Found !!!
Old Dec 3, 2004 | 01:18 PM
Marcel Burkett's Avatar
Thumbs up Look AT What I Found !!!
An oil pedestil adapter for use with oil pressure and temperature gauges, follow the link : http://www.mazdatrix.com/b7.htm
For a third gen though , its not a direct fit , it will bolt up to the block , but the banlo bolt on the oil line wouldn't line up correctly , it would have to be modified .
I think I'll just put a foot or two of SS braided hose at the end of the oil pipe with the appropriate fittings.
Attached Thumbnails Look What I Found !!!-oil-adapter-2.jpg   Look What I Found !!!-oil-adapter.jpg   Look What I Found !!!-oil-adapter-3.jpg
Old Dec 3, 2004 | 05:21 PM
SPOautos's Avatar
Hey, where did my $$$ go?
You know that the Greddy oil temp gauge comes with an adapter similar to this. I image all you'd need if you also want a pressure gauge is to drill and tap into that same adapter. Hell, it might even already have a hole for it, I dont remember. Its a pretty nice piece and doesnt move the filter up near that high. The Greddy adapter is only about an inch or so tall (from my memory...which is sometimes bad haha)
Stephen
Bauer778
Nov 4, 2015 04:42 PM
GreyBush
Sep 14, 2015 01:29 PM
GreyBush
Sep 12, 2015 02:23 AM
