Need immediate rats nest removal help
Old Nov 28, 2004 | 08:12 PM
Dan_s_young's Avatar
Turbo widebody FB
Ok well today i removed my rats nest and got my car all back together. There is a really loud noise coming from what sounds like just past the passenger side firewall Im wondering if this could be from one of the Cat converter vacuum lines please try to help, I need my car for tomorrow thanks lots
Old Nov 28, 2004 | 08:26 PM
Richard Miller's Avatar
Damn, it did start!
do you stilll have the cat?
Old Nov 28, 2004 | 08:40 PM
Turbo widebody FB
Yes... But ok i just found my problem and like i said I need help right now!!!! My block off plate didnt hold... When i was removing the stud it broke and when i was tightening the block off plate in one of those bolts broke as well so im wondering what can i do???? Only 1 bolt can be used to hold the block off plate but it isnt enough.... Would some kinda liquid weld crap or something work? Thanks for the help please respond ASAP!!!
Old Nov 28, 2004 | 08:50 PM
Damn, it did start!
I would suggest some epoxy, but i dont think you will have the time as it takes 24 hrs to cure, maybe more. I may be talking out of my ***, but I believe you could epoxy it and use the backing plate as a mold to keep the epoxy in place.
Old Nov 28, 2004 | 09:40 PM
Turbo widebody FB
actually this is kinda what I did and im praying to god it works... I got some cold weld and spread it all around the outside edge of my block off plate then on the one nut that wasnt broken i put on a couple larger washers in order to more evenly distribute some pressure on the plate im gonna let it cure overnight I sure hope it works....
