Weber 48 IDA
Old Nov 26, 2004 | 09:53 AM
Mikeydred's Avatar
83 Limited Edition
Weber 48 IDA
Just wanted to know if the Weber 48 IDA is too much for a stock port 12A. Any info would be great. Thanks guys!
Old Nov 26, 2004 | 09:55 AM
d0 Luck's Avatar
raysspl.com
nope! it will just all depend on the jetting. PM wackyracer since he owns a 48 IDA atop of the 12a
Old Nov 26, 2004 | 09:59 AM
Mikeydred's Avatar
83 Limited Edition
Thanks d0 Luck!
Old Nov 26, 2004 | 12:38 PM
CHEF_EG_1's Avatar
Rollin' coal and 53mpg!
I had it, and it works BEAUTIFULLY.
the only problem I had was getting an air filter in there. K &N makes one that will fit, but get the shortest one you can... otherwise the hood won't close.
BTW...here's the jetting I used on a stock port:
Air jets: 135
Fuel (aka "Main") jets: 180
emulsion tube: F11
Needle seat: 3mm
Venturi: 40mm
Fuel pressure: 2.75psi
Fuel pump: Holley Blue
It ran rich as hell down low (idle-2500), but above 2500, the a/f ratio smoothed out, and was dead on the rest of the powerband. Words of advice: IT'S THIRSTY. I averaged 12mpg on the hwy, and about 6-10 in town, depending on how much I got on it. (I love the way the RB Streetport exhaust sounds at WOT, and the carb is loud as hell too... so, your results may vary )
Hope that helps.
--Evan
Old Nov 26, 2004 | 03:36 PM
Mikeydred's Avatar
83 Limited Edition
Thanks for the info Chef!
Old Nov 26, 2004 | 05:21 PM
REVHED's Avatar
Hunting Skylines
40mm venturis are probably a bit big for a stock port. I'd go with 38's.
Old Nov 27, 2004 | 11:23 AM
Mikeydred's Avatar
83 Limited Edition
Thanks Revhed!
Coochas
44
Nov 5, 2019 11:08 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
NLPerformance
Oct 2, 2015 07:11 AM
