I lost a lot of boost
Old Dec 6, 2001 | 11:35 AM
Maltese RX7's Avatar
From 12 - 9 -12 now I am 7 - 4 - 7.
Ok I just changed my muffler but loosing 5 Psi is not from the muffler.
I can hear a loud leak .........ssssssSSSSSS...... from the dash when I'm driving.
Must be some leak from the turbo.
Where can I look please?
Old Dec 6, 2001 | 11:59 AM
mmaragos's Avatar
Failure of the stock Y-pipe connector is a common cause of boost leakage.
Go here for more troubleshooting:
http://www.scuderiaciriani.com/rx7/boost_problems.html
Old Dec 6, 2001 | 12:31 PM
Pressurized's Avatar
Yeah, I'd check the Y-pipe and also the tubes leading too and from the intercooler, they tend to split with age.
But start with the simplest thing first. Is your muffler tightened? Could be exhaust leaking.
Old Dec 6, 2001 | 03:02 PM
Similar problem
I had a very similar problem which turned out to be one of the large rubber hoses coming off the air pump. It had a large split from age, and it was only a $20 part.
immanuel__7
Megasquirt Forum
14
Sep 7, 2015 07:25 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
