ZX1 Micro Oil Metal Treatment-safe for rotary??
Old Nov 22, 2004 | 03:43 PM
dfm's Avatar
dfm
I just wondered if you guys would have a look at this web site for me , http://www.team-zx1.com/noflash.cfm , and see what you recon to the zx1 extra lube addative, ive used it in my lexus soarer twin turbo, and ist been very good, just dont know if its safe in the rotary, it says its safe for 2 strokes (so must combust ok), and it recomends putting it in the fuel every now ang again to help lubricate valves, and upper cylinders in piston engines, ect (would this help tips and chamber tho) , let me know what you recon, cheers, Chris
Old Nov 22, 2004 | 04:32 PM
Kento's Avatar
2/4 wheel cornering fiend
Don't waste your money. There's a reason that the majority of the "miracle" oil additives like Prolong, XR-1, Duralube, etc., have basically disappeared from the U.S. market: the FTC declared that their advertisements were misleading, and were banned from making these claims. Consumer Reports and Car&Driver both did exposes on the Prolong stuff.
Old Nov 22, 2004 | 04:37 PM
mad_7tist's Avatar
/\ i thought z-max tuned out to be colored mineral oil
Old Nov 22, 2004 | 04:52 PM
dfm's Avatar
dfm
ok then, il think il give it a miss, what oil tho, i want synthetic (mobil 1 super synth), the handbooks recons 5w 30, its a jdm type r on a '92 , but from what ive read on here alot of peole use thicker oil, and i also want to use some synthetic 2 stroke oil in the fuel, buts whats the best ratio, (be running on 98 octane fuel if it makes any differnece), info is appreciated guys, as its my first rex and dont know to much about them, cheers.
Old Nov 22, 2004 | 04:55 PM
Kento's Avatar
That's what I heard and read....
I believe they were given a "cease and desist" order from FTC...
Old Nov 22, 2004 | 04:58 PM
mad_7tist's Avatar
what is the weather like there now? it is a consideration in oil selection. with a functiong oil metering pump 4-8oz is the common premix ratio to a full tank. (assuming us and jdm have same capacity) tcwIII premix should do. welcome and have fun. also search through the forum as you could spend weeks asking alot of questions that have been anwsered pretty well before.
Old Nov 22, 2004 | 05:05 PM
dfm's Avatar
dfm
its winter here now, not that much over freezing in the day, the cars not used very much, weekend cruising and the odd show ect, so it wont be a daily driver, and by premix, do you mean any 2 stroke oil that you mix to fuel (like a chainsaw ect would have), have a look at this link, seems to be the best one i can get here in the uk http://www.demon-tweeks.co.uk/catalo...&action=detail , does that like it would be suitable?
Old Nov 22, 2004 | 05:14 PM
dfm's Avatar
dfm
or is this link the correct stuff http://www.demon-tweeks.co.uk/catalo...LE&from=search , sorry to be asking stupid questions, but whats the difference between pre-mix 2 stroke oil, and normal 2 stroke oil
Old Nov 22, 2004 | 05:47 PM
dfm's Avatar
dfm
the only pre-mix's i can find over here that ive heard u guys mention is SILKOLENE
Pro 2, and red line kart oil (says use as normal or premix), is the silkolene a good make?
Old Nov 22, 2004 | 06:31 PM
Kento's Avatar
Yes, I've used Silkolene in both two-stroke and four-stroke motorcycle racing engines, and it's worked well.
There are some two-stroke oils that actually made for oil injector systems (somewhat similar to the FD's OMP) that are slightly higher viscosity, while others are strictly pre-mix.
Old Nov 22, 2004 | 06:48 PM
dfm's Avatar
dfm
cheers mate, il get myself some of that.
The1Sun
Mar 18, 2018 11:08 PM
BLK 93
Aug 19, 2015 03:47 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
