Corner seals - experienced engine builders please
Old Nov 19, 2004 | 07:22 PM
fdbabb's Avatar
corner seals - experienced engine builders please
Saw this on Ebay:
Summary
Engine is used, rebuilt- not been started.  It has brand new
internals- new 3MM HD apex seals and springs, new side seals and springs,
new corner seals (without the rubber insert) and springs, and rotor side
o-rings and springs.
Whats the advantage of not using the rubber inserts in the corner seals?
Is there a material that could replace the rubber if the rubber is not good for whatever reason???
Old Nov 20, 2004 | 01:32 AM
drago86's Avatar
the rubber piece is usually only left out with big street ports or bridge ports,.. its only really there for a little bit of cranking pressure,.. the car will be down a lil on cranking compression without them but it shouldnt really effect anything.
Old Nov 20, 2004 | 02:09 PM
fdbabb's Avatar
Ah, so they're taken out so they don't interfere with the port in some way, depending on how your port is configured or cut, right?
I have an aggressive street port (Atkins). I've always felt the rubber piece was dead meat after running near 16-1700 degrees of combustion heat and sitting in a 200-250 degree piece of metal for hours at a time. I thinks it hardens and is ineffective after that. Mine were hardened and would leave black marks all over your fingers.... ANYWAY......
That said, could I get a round plug of VITON and mill a channel and match the dimensions of the rubber insert's dimensions, and expect it to work better for longer?
THANKS!!!
Old Dec 8, 2004 | 01:09 PM
stevecod's Avatar
they left out the rubber inserts because he's got thicker seals now(3mm). and the stock rubber inserts won't fit into the 3mm seals. they sell 3mm inserts i believe at RB.
steve
Old Dec 8, 2004 | 10:20 PM
patman's Avatar
Resident Know-it-All
^^ what he said. yeah..if youve got the equipment, milling it out of viton would be fine. rotaryaviation sells them as a 'cord'.. long strip of viton with a slot cut in it that you cut to fit your own seals.
pat
sYnth.
Aug 19, 2015 06:27 PM
