strut tower bar for the rear
Old Dec 5, 2001 | 04:55 PM
2FAST7S's Avatar
I just bought and received a strut tower bar for my FC. I got it from JC Whitney...I probably shouldnt have but I figured its cheap and if it doesnt fit, I can still use it on either the front or my FD. As I suspected, the box says clearly 93-95 RX-7. which i dont really mind since I can use it.
My question is, does anyone out there sell or make the rear strut tower brace for second gens? I dont want to go ahead and order another one and have to send it back cause(like J C Whitney) they sort of goofed!!!
Manny
Old Dec 5, 2001 | 06:47 PM
E6KT2's Avatar
Corksport has the Mazdaspeed unit listed on their webpage. I heard Cusco makes one as well. Good Luck!
Old Dec 5, 2001 | 10:09 PM
Scott 89t2's Avatar
SOLD THE RX-7!
cusco makes an alum. one for around 150, at corksport, rx7.com, or the store link on this site. they also have a carbon fiber one for 230. you have to cut up your shock towers a bit. the mazdaspeed one you don't have to but it costs more and probably isn't as strong.
thye also both make front lower bars for fc for $110-130. I'll be ordering one in the spring. the mazda speed one looks much better and is only a bit more then the cusco.
Old Dec 5, 2001 | 11:22 PM
ReZ311's Avatar
KM48 Burnout
CUSCO is the best. I got both upper and lower on the front. makes a hell of a difference!
Old Dec 5, 2001 | 11:25 PM
ReZ311's Avatar
KM48 Burnout
oh. here is a link for some pics for the FC CUSCO sway bars. blue on bottom, chrome/silver on top(but the top one is trust... trust and cusco.. ummm same thng) I also got the big anti sway kit that replaces the stock one. It is red.
http://www.calinetworks.net/rez/CUSCO/
Old Dec 6, 2001 | 05:07 AM
turboren's Avatar
What's the point in tying the rear of the LCA's together? doesn't that big *** engine crossmember provide enough lateral support on the bottom? Top I can understand, because it gaps a large hole, but the bottom seems pretty strong as is. Educate me, please.
The best design I've seen for an upper strut tower bar was from Mazdatrix. It's a little on the pricay side, at $320 or so, but triangulated the strut towers to the firewall. I think they still sell it, but I haven't looked for it in a while (no money).
Ren
Old Dec 6, 2001 | 08:07 AM
FEDREX's Avatar
"Just Looking".......
I have the Mazdaspeed front brace and rear strut brace and can't imagine anything being stronger. Both braces are about 1 3/4" wide and about 5/8" thick shaped like a flattened oval with an indentation running the length on the front edge and the rear edge.
The fit is superb. For the rear, all I did was drill holes in the shock tower carpeting for the included bolts to fasten to EXISTING holes in the shock tower.
They are polished aluminum braces with gold-anodized brackets. In the center top of the brace there is a stamped Mazdaspeed logo......these parts are very rigid and flawless.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
rkhanso
Aug 13, 2015 11:40 AM
