What can i get away with?
Old Dec 5, 2001 | 10:50 AM
COLBALT's Avatar
i have
10mm wires
front mount IC
and Full exhaust
no cats
but i only have about 300 for an ecu right now
what can i do for the ecu to run the mods?
Old Dec 5, 2001 | 11:57 AM
Flybye's Avatar
It's never fast enough...
Re: What can i get away with?
You pray
I wouldn't even recommend boosting, but if you must, then make sure you don't boost past 10psi (You better decide a way to control it), hook up a voltimeter to the O2 sensor, and make sure you are above .85v. If you are below .85v, then you better not boost at all.
Old Dec 5, 2001 | 12:07 PM
rx7eaven's Avatar
I don't think that you can get away with much. I would definately save up and purchase a nice ecu. Without it...Pop!! Not something that you want.
Old Dec 5, 2001 | 12:35 PM
COLBALT's Avatar
ecu
if i have a boostcontrol and fiel fule computer will i be ok?
and a fule cut defencer?
Old Dec 5, 2001 | 12:41 PM
fuel cut defencer dont do ****, it actually lies by saying your boost is lower than it really is to avoid cut off, not good...
what kind of fuel computer?
remember, ecu is cheaper than a motor!
Old Dec 5, 2001 | 12:57 PM
COLBALT's Avatar
it's a field sfc hyper
i don't want to run any more than stock boost
Old Dec 5, 2001 | 12:58 PM
jumprdude's Avatar
don't run your car like that...
you will eventually blow the engine. And my bet is sooner rather than later.
Try to see if you can get a used pettit reprogrammed ecu somewhere. Or you can get a high-flow fuel pump, rising-rate fuel pressure regulator, and hope for the best.
Old Dec 5, 2001 | 01:01 PM
jumprdude's Avatar
without the main cat, you will not be able to control boost effectively, unless you have a ported wastegate. And even if you were able to keep it at stock boost levels, the better volumetric efficiency from your intake/IC/exhaust mods would require more fuel.
Old Dec 5, 2001 | 01:09 PM
COLBALT's Avatar
i will have to look for one
will a pittit unlimeted ecu work good for me?
