Body work people lend me your ears
Heh... I am not much of a body work person so can anyone tell how bad this is. Also best recommendations on the best way to fix it.
http://webpages.charter.net/acidshock/Wreck/
Both of the doors can be opened without scraping although the hood does scrape the rear of the passenger fender and the front of the driver side. It of course is difficult to open or shut the hood completely because the bumper is pushed back and to the side.
It may not be as bad as you think. I thought with the way the right side looked, it took the fender and inner structure and moved it back. As you are going to do, just pull the front bumper off and take a look at the radiator support etc. to get a better idea of what needs to be adjusted, or pulled out.
Maybe one of the body experts will jump in.
The fender can be tweeked back and the dent can be hammered out then the remaing filled. The bumper cover is shot, possibly the core support and or bumper reinforcment is tweeked. All in all thats a simple repair, get a used cover and a cheep hammer and dolly. If you don't know how to use a hamer and dolly send me a pm and I can tell you how you should go about bummping the dent.
Trending Topics
New bumper for sure. Fender can be fixed, but the laber spent on fixing it can be used to by a new aftermarket one. Plus you won't have to worry about the bondo cracking on a new fender. Me I would go with the second option. Might end up costing you more in the long run. Tony
It doesn't look too bad, but it does have some structual damage.Looks like you have to pull the rad. support (core support) just a little, it doesn't look like you have to replace the bumper reinforment, but i would just in case it happens again it could take the impact of the hit.Once you pull the rad. support everything should line up just fine.The bumper does have to be replaced and the fender could be fixed.
