Jacobs Rotary Pro-Pack
Old Nov 15, 2004 | 11:03 AM
does anyone have the instructions for this thing? i just bought it off my buddy but he doesn't have the directions anymore so i'm confused....lol
Loi
Old Nov 15, 2004 | 11:44 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
i run the newer edition J RPP and am very happy w it. i bought it from Ari's shop. at the time they were running one on the lead plugs and making approx 700 h p. that's good enough for me i run a T2 coil on the leading plugs as they recommend.
if you have the newer model i can help you w the wiring etc.
howard coleman
Old Nov 16, 2004 | 01:34 PM
i don't know if its the newer version or not, it has 6 wires. a plug with white and green wires, another with red and black wires and 2 wires marked for + and - battery terminals. i'm trying to use this on my 1st gen distributer setup. the ignition box came off a 2rd gen, just FYI.
Loi
Old Nov 16, 2004 | 01:42 PM
nin-ja's Avatar
I got these from Rocky at RX7.com about 2 or 3 years ago
Additional instructions for rotary installation 86-91 RX7
The Jacob's Energy Pak will be installed on the leading coil set. The
leading coil set is located under the hood, behind the driver's side
headlight.
Before installation please disconnect negative battery cable and leading
spark plug wires.
Remove black plastic coil terminal cover form coil (marked with L1 L2),
and disconnect the brown and black wires from the coil.
Connect wires from Energy Pak as follows (4 conductor black cable).
Energy Pak car
red brown (went to coil originally) from igniter
green black (went to coil originally) from igniter
white + terminal of coil (where brown wire was connected)
black - terminal of coil (where black wire was connected)
You replace black plastic coil terminal cover.
Don't forget to connect the thin black wire to a good metal ground.
Connect the heavy red wire to battery (+) positive terminal and heavy
black wire to battery (-) negative terminal.
Install fuse and fuse cover.
Old Nov 18, 2004 | 05:57 PM
fastrotaries's Avatar
W. TX chirpin Monkey
I have intructions with pics, but it's for a FC. Don't knowif it helps.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
