Tips on changing spark plugs?
Old Dec 4, 2001 | 07:15 PM
Its about that time again...time to change the spark plugs. Just wondering whether anyone has an easier suggestion to changing the spark plugs, other than removing all the crap on top....oil tower, etc. thanks.
Old Dec 4, 2001 | 07:24 PM
ErnieT's Avatar
Living life 9 seconds at a time
Yea, much easier to just jack the car up and get to all 4 plugs from underneath the driverside of the car.
Old Dec 4, 2001 | 07:25 PM
rx7ofmine's Avatar
Get a set of ramps if you don't already have one. change the plugs from the bottom, dont need to remove anything. It only takes about 15 min to do.
Old Dec 4, 2001 | 08:02 PM
GsrSol's Avatar
Z06 powered FD
You don't have to remove anything.
I just did mine today and took about 15-20 minutes. I go from the top and use a 4" extension only on the rear housing.
Alot easier to go from the bottom but I didn't feel like busting out the jack and stands.
Thanks guys/gals...I'll try that later. My only question now, is that the last time I changed my plugs, I remeber there being something blocking the way.....making it very hard to remove the boot....I think it was the oil tower, but not sure..
Old Dec 4, 2001 | 08:17 PM
rx7ofmine's Avatar
If you are going in from the bottom, there is only one plug that's going to be a little blocked. It's the trailing plug for the front rotor, it is part of the engine wiring harness that gets in the way. The other 3 are all clear.
Old Dec 4, 2001 | 10:36 PM
thanks again people. where would I be without this forum
Old Dec 4, 2001 | 11:31 PM
Someone mentioned to me that a special socket might be needed since the spark plug is in a narrow opening. Is this true?
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
Joe428
16
Aug 19, 2015 06:24 PM
