just got a rx7
Old Nov 9, 2004 | 09:30 PM
slpin's Avatar
7th Heaven
just got a rx7
just got a 87 rx7, 5 spd, silver, with red interior, 1.6k and 117k miles
the car seems to drive pretty nice, starts right up,
but i have a few questions
what rpm is it suppose to idle at? it idles around 650rpm, shouldnt it idle higher?
when i rev it, and when it drops from 1000rpm to 650rpm, there seems to be knocking from the passenger rear, what could i look for?
how can i tell if my 5th and 6th port is opening? which solenoid is it?
also, 2nd gear is louder compare to the other gears - is that ok?
Old Nov 9, 2004 | 10:30 PM
slpin's Avatar
7th Heaven
i figured out the idle, got it at 800rpm, so much better... if i try to back the screw out more, it gets hard to turn.... should i keep going?
Old Nov 9, 2004 | 11:34 PM
casio's Avatar
casio isn't here.
750 is normal idle rpm. i aim for "that area."
not sure about the knocking. sounds like its bad, though.
not sure about testing aux ports, honestly.
Old Nov 9, 2004 | 11:53 PM
slpin's Avatar
7th Heaven
i think the knocking is from the metal banging or motor/transmission mounts?
how much are those???
oh, i backed out the screw on the throttl ebody all the way and th ehighest idle i could get is 750rpm???
Th0m4s
Feb 26, 2019 02:04 AM
