Anyone wire in a 2nd set of injectors?
Old Nov 8, 2004 | 09:40 PM
Rotorhead34's Avatar
Scream baby Scream!!!
Question Anyone wire in a 2nd set of injectors?
I have a first gen and need to wire in a 2nd set of injectors. Do I wire them into the two injectors all ready there or will a fuel controller allow this? Also, how does a fuel cut defender work?
Attached Thumbnails Anyone wire in a 2nd set of injectors?-dsc_4755.jpeg   Anyone wire in a 2nd set of injectors?-432763_23.jpeg
Old Nov 9, 2004 | 02:22 AM
rotarygod's Avatar
Rotors still spinning
You have to have some form of control for them. You can't just wire them in along with you stock injectors and expect them to work good. If you have an additional injector controller you could add them in but I would recommend a standalone type of ecu.
A fuel cut defender is only needed on the 2nd generation Turbo II. The ecu cuts fuel to the engine above a certain boost level. The fuel cut defender fools the ecu into thinking that there is less boost so this doesn't happen and so higher boost can be used.
eddierotary
Aug 16, 2015 04:12 PM
