First dyno since it's off the boat
Old Nov 5, 2004 | 11:25 PM
Pilx's Avatar
FC3S
First dyno since its landed
This is a JDM '89 Turbo FC (Savanna ) with an oversized POD and Exhaust as the only performance mods at the moment. Also has 82,000kms on the clock and standard ECU.
Since I still have to wait another 2 weeks till it will be road registered, I decided to take it in for a quick dyno to check AFRs and power output.
It managed to get 135rwkw's at 6500rpm and the afrs are all good after 4000rpm.
However... as you can see it was only boosting to 6psi max, and since it's a S5 it should be making it to around 7-8psi. I'm guessing it might be a problem with the wastegate or maybe something like a blocked CAT, any other ideas?
I'm not really fussed about it at the moment since once it's finally on the road I've got a highflowed s5 turbo sitting here to go in, and also strip the emissions control devices and get a cat pipe etc..
Old Nov 5, 2004 | 11:38 PM
Pilx's Avatar
FC3S
Here's a quick pic of it
Old Nov 5, 2004 | 11:45 PM
z4csl428's Avatar
From: Seymour, TN (couple miles west of the atlantic ocean)
not too good at converting Kw's to HP but that is one beautiful car. keep her clean....
Old Nov 6, 2004 | 12:03 AM
RETed's Avatar
http://www.onlineconversion.com/power.htm
181hp
But if we factor in 15% driveline friction, it's about 213bhp at the flywheel.
We don't know the specs of all the mods.
If it has cats on it, this would be about right.
If it's a full exhaust, it's a bit low.
-Ted
Old Nov 6, 2004 | 12:36 AM
FDreaming's Avatar
S4 now S6 soon...
Sexy! What kind of the wing is that?
Old Nov 6, 2004 | 01:22 AM
Mark'sMazda's Avatar
stop stealing my avatar
what is an over sized POD?
Old Nov 6, 2004 | 01:26 AM
dreamnshadow's Avatar
what size tires are u running? i'm assuming those are vert rims.
Old Nov 6, 2004 | 04:16 AM
Pilx's Avatar
FC3S
Like a regular K&N pod just ... bigger
The wing is a generic type drift wing, no idea who makes it but it has a nice look to from an angle. It's too bad it wasn't fitted properly in japan and now opening the hatch is a pain since it rubs on the corners and is really hard to get up from the outside
The rear rims are oldschool SSR dish rims and the fronts, I *think*, are genuine infini rims. Not sure about the tyres off the top of my head, I know the fronts are 195's, the rears might be 215's.
Oh and the front bar is a re amemiya, which is awesome
Also has tein HA coilovers and a mazdaspeed 2way lsd.
Old Nov 17, 2004 | 08:38 PM
Dom_C's Avatar
**** there are no Flash to pass lenses. . i thought it looked a bit odd. . is this common with jspec. . or jsut tii first time i've seen taht. . odd. . but not bad. nice car
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
