Got a use motor in... now boost issue!
Old Nov 5, 2004 | 05:30 PM
z28_SS's Avatar
--Almost Retired--
Unhappy Got a use motor in... now boost issue!
Okay, I've bought a use, complete motor with turbos at this one wrecking yard.
Got it on my FD and fire right away. After about 10 min of letting it warm up and idle, I took it out for a spin...
On first gear, Primary boost will reach 10, and transition at 0 then at 5.5 rpm or 6K RPM the secondary turbo will come on. But in 2nd and 3rd gear boost will come flawless. Sometimes....
Just happen to be on 1st gear the most that on 4.5 RPM 2ndary boost dont come on till 5.5 to 6 K...
what do you guys think could be the problem...
Old Nov 5, 2004 | 05:35 PM
ejmack1's Avatar
Lawn Ornament
your signature is the problem... get rid of it
Old Nov 5, 2004 | 05:37 PM
RotorJoe's Avatar
Hooray For Boobies!!!
/\ Same here
Old Nov 5, 2004 | 05:39 PM
z28_SS's Avatar
--Almost Retired--
what's wrong with the z28..
No rice here...
Old Nov 5, 2004 | 05:40 PM
z28_SS's Avatar
--Almost Retired--
Angry
Okay,
since u guys make me look dumb and took it off, tell me what's making it do like that...!!
I've checked vac., CRV... all that.. Seems to be working fine. But does seem like theres a leak coming from the downpipe..
Old Nov 5, 2004 | 05:43 PM
ejmack1's Avatar
Lawn Ornament
have you searched the forums for problem like this?
I can recall 3-4 topics off the top of my head that are about this... Hell i can recall 2-3 websites that deal with this....
Old Nov 5, 2004 | 06:05 PM
RotorJoe's Avatar
https://www.rx7club.com/showthread.p...boost+problems
https://www.rx7club.com/showthread.p...=Boost+Problem
What I found on the first two pages of my search. I would dig deeper to find more, but this may help.
It's just not a 7. If you want large pics as sigs, then they have to be boobies or an rx7
Old Nov 5, 2004 | 07:55 PM
z28_SS's Avatar
--Almost Retired--
Yes, I've search... and found results, but most of them are not like mine.
I guess, squential problem is such a common problem that could relate to tons of issue..
I'm thinking about selling it now come to think of it...
13.5K and it's yours...
Old Nov 5, 2004 | 07:58 PM
z28_SS's Avatar
--Almost Retired--
Originally Posted by x605p747R1
[url]http
Well I bet my Z28 could hand your FD *** to ya...
Old Nov 5, 2004 | 09:47 PM
seanbrowning's Avatar
I do believe you should come down to Tampa Bay and meet a '93 F1 friend of mind who would more than likely tap that z28, considering his car is setup to take down bikes.
Old Nov 5, 2004 | 09:51 PM
ejmack1's Avatar
Lawn Ornament
I would be willing to wager a large amount of money that that piece of **** could not hand my FD *** to me....
please sell the car and go back to www.mulletlovers.com
Old Nov 5, 2004 | 11:15 PM
Mahjik's Avatar
Mr. Links
Arrow
The Turbo Control Solenoid / Actuator is one of the more complicated actuators as it requires both vacuum and pressure to operate properly. This actuator is controlled by two solenoids, (both are wired together to the one ECU output) one solenoid applies pressure to one side of the actuator and the other applies vacuum to the other side of the actuator. With pressure on one side and a vacuum on the other side of the actuator, the speed of the actuator is improved. A typical problem is loss of Secondary boost in 1st or 2nd gear at 4,500 RPM, but reliable operation in other gears. This points to one side of the Turbo Control Actuator not getting it's pressure/vacuum, so it will still operate but not quickly enough.
http://www.autosportracetech.com/RX-...leshooting.htm
Old Nov 5, 2004 | 11:22 PM
z28_SS's Avatar
--Almost Retired--
Talking
[/url]
Dude who say I was talking to you...
Either way, it was a race you never won...
Old Nov 5, 2004 | 11:26 PM
z28_SS's Avatar
--Almost Retired--
Thanks again Mahjik, makes sense, but where exactly is the The Turbo Control Solenoid / Actuator??
x605p747R1,
I take my words back, I just saw your mods and maybe you can hand my z28 *** to me...
Old Nov 6, 2004 | 07:02 AM
Mahjik's Avatar
Mr. Links
There are two turbo control solenoids:
http://www.scuderiaciriani.com/rx7/v...e_diagram2.jpg
One on the ACV and one on the solenoid rack. Both must be tested and checked for failure as well as the vacuum lines to and from them.
The actuator:
http://www.autosportracetech.com/RX-...BigPicture.htm
Old Nov 6, 2004 | 07:23 AM
bajaman's Avatar
Constant threat
You actually found a used engine for sale at a salvage yard? If you don't mind telling, how much did you have to give for it, and where did you get it?
I found ONE wrecked FD in the Wichita area and the engine in it was already gone.
Old Nov 6, 2004 | 10:38 AM
z28_SS's Avatar
--Almost Retired--
I bought it for $3,000 cash out the door, with a warrantee of 6 months... The warrantee state that it has good and high compression on both rotors, and warrant any coolant seals, apex seals and etc... if those were to go out on me...
My friend got it for me in Rancho Cordova, Sacramento...
Old Nov 6, 2004 | 11:30 AM
z28_SS's Avatar
--Almost Retired--
Originally Posted by Mahjik
which particular actuator should I look at...
the actuator (charge control)
the actuator (Turbo Pre Control)
the actuator (Wastegate Control)
or the actuator (Turbo Control)
Old Nov 6, 2004 | 11:52 AM
ejmack1's Avatar
Lawn Ornament
Wait is Mazdaperformance or whatever in Rancho? or was that Roseville...
was this just a regular junk yard, cause i dont remember any rotary specific places in rancho, especially since K2RD moved
Old Nov 6, 2004 | 12:30 PM
z28_SS's Avatar
--Almost Retired--
Yes it's in Rancho, or wait, I think it's "Sunrise"... I remember it was a Mazda something place.. Dirty looking place, but has alot of wrecked FDs....
Old Nov 6, 2004 | 03:17 PM
Mahjik's Avatar
Mr. Links
Turbo Control as the troubleshoot site says.
Old Nov 6, 2004 | 05:20 PM
z28_SS's Avatar
--Almost Retired--
thanks alot Mahjik...
That will do..
Old Nov 7, 2004 | 07:39 PM
RotorJoe's Avatar
x605p747R1,
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
befarrer
Aug 14, 2015 04:18 PM
