Just bought Efini Y-Pipe
Old Nov 5, 2004 | 03:51 PM
kevinvr6's Avatar
Gremlin Hunter
Why does the y-pipe look modified? I bought it from rx7store. What did it look like before it was hacked up? I'm guessing it was trimmed for fitment...
Is there anything I should look out for (becareful with when taking apart and reinstalling?)
Thanks!
Attached Thumbnails Just bought Efini Y-Pipe-y.jpg   Just bought Efini Y-Pipe-y2.jpg
Old Nov 5, 2004 | 04:00 PM
adam c's Avatar
Cheap Bastard
That is a stock efini y-pipe. Some people polish them on the outside for looks. Just take your time installing it. It isn't that difficult. You will have to remove the air pump.
Old Nov 5, 2004 | 04:05 PM
tiger18's Avatar
LOL the bits that the green arrows are pointing to,,,are the cast marks . the pipe is cast in 2 pieces and then moulded together,,,,..they can be ground down and blended into the pipe to make them dissapear.
Old Nov 5, 2004 | 04:22 PM
DamonB's Avatar
Actually the pipe is cast as a single piece but the mold is in at least three parts. The areas you have marked are typical of all cast parts that have not been completely cleaned up afterwards. They won't harm anything. Grind them off if they bother you.
Old Nov 5, 2004 | 04:23 PM
fd3s_rx7's Avatar
exactly what DamonB says/...
Old Nov 5, 2004 | 04:30 PM
kevinvr6's Avatar
Gremlin Hunter
phew ok cool thanks guys.
I already have the airpump off since i just finished changing all my hoses to silicone. should I eliminate the EGR while im there? what things do I need to cap off?
Rockin!
Old Nov 5, 2004 | 04:49 PM
DaleClark's Avatar
RX-7 Bad Ass
For the EGR, you just need a blockoff plate and to cap off the vacuum nipple that went to the EGR valve. I'd install the blockoff plate with a new gasket and do it right, BTW.
Dale
Old Nov 5, 2004 | 05:31 PM
turbojeff's Avatar
Do it right, do it once
What DamonB said...
Sometimes the excess material marks are called "witness" lines from the mold. Molds (commonly called "the tool") leaves these witness lines where the pieces of the mold come apart.
Look at any cast or injection molded plastic and you'll see these type of marks. They are really big on lower quality parts and smaller on higher quality parts. Example, look at the throttle body casting quality vs. the intake manifold.
Old Nov 5, 2004 | 05:48 PM
BlueRex's Avatar
Dale
If you have a '94 RX-7 then you will get the CEL if you just block it off. You need to install a 12v relay to fool the ECU into thinking the EGR is still working. Read the FAQ's there are several useful threads for EGR elimination.
EDIT: This may only occur on CA ECU's.
Old Nov 5, 2004 | 06:07 PM
rotoboy661's Avatar
looks nasty
haha
its alrite kev your just trippin;
mike
t-von
Sep 10, 2015 01:56 PM
