Which plugs lead/Trail
Old Nov 5, 2004 | 03:12 PM
ranger306ci's Avatar
DILLIGAF?
Question Which plugs lead/Trail
Ok, I am new to wankles, but they aren't too difficult to figure out for the most part.
But one thing is perplexing me.
Looking at the side of my 13B block, I noticed the top spark plugs have a "T" next to them , and the bottom ones have an "L" next to them. Tracing the plug wires back to the cap, the same indications are on the cap.
So, I WAS under the impression that my top plugs were leading, and the bottom ones were trailing. But the markings seem to indicate otherwise.
I thought the rotor wobbled(spins) clockwise when you are facing the front of the engine, which would lead me to believe the top plugs fire first. Am I AFU?
Old Nov 5, 2004 | 03:21 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
Nope, rotation it's the other way around. Leading Low, Trailing Top.
Old Nov 5, 2004 | 04:11 PM
REVHED's Avatar
Hunting Skylines
Rotation is not the other way around! The rotor passes the top (trailing) plug first but it doesn't fire till after the bottom (leading) plug does.
Old Nov 5, 2004 | 04:18 PM
cdrad51's Avatar
You're right, my bad, if facing the front of the engine, with spark plugs to the right and ports to the left, the rotation is clockwise.
Old Nov 5, 2004 | 04:32 PM
Jeff20B's Avatar
Lapping = Fapping
You can think of it like this. The compression 'dish' is longer than the distance seperating the plugs. As the rotor face comes around, the leading section of the dish gets close and personal with the leading plug first. The leading plug fires into the compression dish and as the flame front begins to travel toward the trailing edge of the dish, the trailing plug fires into the trailing section of the dish a few degrees later.
There are differences in compression 'dish' shape and spark plug locations in 12As and 13Bs. This is why timing and L/T split are a little different for each engine.
Here is a visual for you of when the plugs fire in relation to rotor position. http://www.rotaryengineillustrated.c...es/an-WCA.html
Edit: That third spark that you see right before the exhaust port opens is a late leading spark which is normal (stock) on '86-'02 RX-7s. Older rotaries with a cap and rotor ignition system do not have this. You can upgrade them though. All my vintage rotaries have it and they run noticeably better, and even sound better.
wretchedegg
Nov 19, 2025 03:07 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
betes
Sep 27, 2015 08:25 AM
ZacMan
Sep 19, 2015 09:20 PM
Enzo1944
Sep 6, 2015 08:57 AM
