HELP!!! TPS same for turbo n/a ?
Old Nov 3, 2004 | 11:55 AM
RX7 allnight's Avatar
Question HELP!!! TPS same for turbo n/a ?
is the TPS sensor the same for s4 N/a and s4 turbo? this guy has a turbo FC and he needs a TPS i have tons can i help him out??? thanks
Old Nov 3, 2004 | 11:58 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
they are the same... S5's are slightly different in the bracket.
Old Nov 3, 2004 | 12:00 PM
SureShot's Avatar
Seduced by the DARK SIDE
I think the black plastic plunger part is the same, but the brackets are different.
You can bend up the ears on the thin metal ataching cover & swap the plunger from one bracket to the other.
If you're handy with solder & heat shrink, you can swap the plugs & do the above between S4's & S5's
Old Nov 3, 2004 | 12:03 PM
You can bend up the ears on the thin metal attacing cover & swap the plunger from one bracket to the other.
thanks for the info
hotshot2014
Jul 18, 2017 02:30 PM
incubuseva
14
Sep 3, 2015 12:37 PM
ncds_fc
Aug 15, 2015 10:06 AM
