What is this and can i get rid of it?
Old Nov 2, 2004 | 09:52 AM
Whizbang's Avatar
Respecognize!
Exclamation What is this and can i get rid of it?
The picture below has a few things that i think are part of the rats nest but i want to know what they are, what they do and if i can get rid of them. Also how to get rid of them. Thanks!
Attached Thumbnails What is this and can i get rid of it?-dsc00407-small-diin.jpg
Old Nov 2, 2004 | 09:58 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
2 is the cold start assist tank.... goes to a solenoid thingy on the back of the LIM.. you can ditch that, but you'll need to make a blockoff plate for the solenoid thingy
1 is the charcoal can... your fuel system vents to this... i'd leave it in there
the stuff on the shocktower the middle is the pressure sensor, you need that..... the others.... hmmm, i never bothered with that i just ripped it out when i did the haltech!!!!
Old Nov 2, 2004 | 10:14 AM
Whizbang's Avatar
Respecognize!
maybe i can move them for the hell of it.
Old Nov 2, 2004 | 11:21 AM
simex's Avatar
I don't know what 3c is but it's totally melted to crap on my car, and the car runs fine, so i'd assume it's not very important.
Old Nov 2, 2004 | 11:47 AM
strikland's Avatar
3c is a variable resistor that I think helps control the air mix at idle, but I may be wrong on that one.
3b is your boost sensor,. I moved mine when I took the stock air box out.
Here's a pic. The FSM is your friend.
File Type: bmp
Old Nov 2, 2004 | 11:53 AM
marlaman's Avatar
Need an E6x
You're correct sir.
Matt
7th Heaven's Avatar
1 is the charcoal canister - mines gone
2 is cold start assist - gone
3a i have no clue
3b pressure sensor - leave it
3c helps tune your idle, it helped me a lot.
Old Nov 2, 2004 | 01:20 PM
oakback's Avatar
meh
Keep 3b and 3c, I have no idea what 3a is (I don't have one on my '86 n/a), ditch 2 and use the block off plate. 1 is optional, it vents the fumes from the gas tank, and from the crank case ventilation.
Old Nov 2, 2004 | 09:02 PM
VietFC's Avatar
what the hell is that 3a thing? i've never ever seen one before.
Old Nov 2, 2004 | 09:04 PM
Makenzie71's Avatar
...94% correct.
holy crap...what is 3a?
Old Nov 2, 2004 | 09:18 PM
inflatablepets's Avatar
That's a soleniod for the automatic transmission if I am not mistaken. Leave the mixture sensor, pressure sensor and the charcoal can. Junk the rest.
Old Nov 2, 2004 | 09:20 PM
ddub's Avatar
i am legendary
I took out my charcoal canister, cold start assist was already gone when I got the car, took out the variable resistor removing it doesn't hurt anything, leave the other two.
Old Nov 2, 2004 | 09:21 PM
VietFC's Avatar
ah, that explains why i've never seen one before. hahah
Old Nov 2, 2004 | 09:31 PM
Kenteth's Avatar
Like Ghandi with a gun
my s5 didnt have one though
Old Nov 2, 2004 | 09:55 PM
7th Heaven's Avatar
wait, a block off plate for the cold start assist? someone post pics, my line that goes to the engine is just capped... if theres more to take off and block off i need to do it. anyone got pics of their setup?!
Old Nov 3, 2004 | 01:34 AM
alexdimen's Avatar
TANSTAFL
don't think so... just capped the brass tube coming from the intake manifold to the resevoir and unbolted the resevoir.
Old Nov 3, 2004 | 02:58 AM
geekster's Avatar
Just out of curiosity... Exactly when is the cold start assist being used? Is it for "engine not warm", sub zero or somewhere in between?
renjiv2
57
Jan 25, 2024 03:34 AM
