Liquid-air ic
Old Nov 2, 2004 | 03:17 AM
MR_Rick's Avatar
Planning my come back
Liquid-air ic
Has some body use a in fuel pump as a water pump for a liquid-air ic set up? I'm just wundering since it will last longer than a regular pump and may be pump faster.
Old Nov 2, 2004 | 06:25 AM
MillSpeed's Avatar
I'd just stick to a marine bilge pump. I've got a Jabsco one. It's built like a brick shithouse so I doubt it'll burn out anytime soon. Plus, you don't want it to pump too fast.
Old Nov 2, 2004 | 09:22 AM
DaleClark's Avatar
RX-7 Bad Ass
The seals in a fuel pump may or may not be rated to pump water. That is an idea, though.
Fuel pumps are easy/cheap enough that it might be worth trying.
Dale
Old Nov 2, 2004 | 09:51 AM
MR_Rick's Avatar
if they seal fuel, they will seal water. seals usually get eat up by fuel, but I'm talking about a inline fuel pump. I just think they are more durable. If you put a voltage regulator you can make it variable speed.
Old Nov 2, 2004 | 10:39 AM
Speed of light's Avatar
Form follows function
Many fuel pumps are of "wet" construction and use the fuel as a coolant in and around the motor. They are also pressure equalized inside to provide a long life. (therefore the seals are different than in a water pump.) I would not recommend attempting to use it to pump water--I don't think it would last.
Try johnson pump. These are smaller than the jabsco and I have had good results with them. I don't have the model # off hand, but if you want it PM me and I will find it for you.
Old Nov 2, 2004 | 12:46 PM
TwinTriangles's Avatar
What's an RX-7 ?
My dad rigged up my old stock FD fuel pump to use in the water injection in his turbo mini cooper, It works awesome...!
Old Nov 3, 2004 | 08:44 AM
ZeroBanger's Avatar
The diaphram pumps I use for my water injection kits are ideal for what you are looking for. They pump 1 gallon per minute and run from 60 - 100 psi depending on what model. You can view them at www.coolingmist.com about midway down.
These are designed as a demand pump so they have instant response and are designed to take a beating.
R.P.M.
Nov 2, 2007 12:51 AM
