running on one rotor!!
Old Nov 1, 2004 | 10:54 PM
Almost's Avatar
ok got a big wiring problem out of the way ... we got spark and fuel and compression is good on both rotors but its very sluggish revs up real slow and has no power and perhaps it feels like its running on one rotor!! what else could it be??
thanks
Old Nov 1, 2004 | 10:58 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Are you sure all injectors are firing correctly? Check the ECU for codes.
Old Nov 1, 2004 | 10:59 PM
satoacs's Avatar
haha i read the title and thought youd have a vid to post of a kill while running on one rotor
Old Nov 1, 2004 | 11:02 PM
Almost's Avatar
ecu is putting out no codes!! i wish i had some cool vids but i havent had the opportunitiy of video taping one yet!!!
Old Nov 1, 2004 | 11:14 PM
Did you actually pull the codes? Only certain codes will cause the actual CEL to come on. I would start with that. I'm guessing one or more of the injectors has failed or is working intermittently. How does it idle?
Old Nov 1, 2004 | 11:46 PM
Almost's Avatar
idles at 1000 just had the injectors cleaned and tested they were about 10-15cc off of what they should be at 550
Old Nov 1, 2004 | 11:57 PM
mort2002's Avatar
my car did the same thing this weekend... it was smoiking alot and lost all power... turns out it was a stuck injector... stuck all the way open on the rear rotor... u might want to check that btw i have a 89 tII
Old Nov 2, 2004 | 12:00 AM
DerangedHermit's Avatar
Do you have cats on it?
Old Nov 2, 2004 | 12:08 AM
Almost's Avatar
yea it has a stock exhaust withhall cats in place one muffler is rotted off tho how can i tell if a injector is tuck open?with a ohm meter or what
Old Nov 2, 2004 | 12:09 AM
Almost's Avatar
this is a 87t2
Old Nov 2, 2004 | 12:13 AM
mort2002's Avatar
well i ad an exahust lean and i had raw fuel coming out of the flange on the pipe... just and idea
Old Nov 2, 2004 | 12:15 AM
Your cats could be clogged, that's my only guess.
Old Nov 2, 2004 | 12:17 AM
Almost's Avatar
ok thanks alot guys forthe help its much appreciated!!
Old Nov 2, 2004 | 03:14 PM
Almost's Avatar
how do u actually pull codes off of the ecu cause ive never heard of that before thanks
Old Nov 2, 2004 | 03:24 PM
WAYNE88N/A's Avatar
If she idles (even at 1000) without your foot on the gas, both rotors are firing...
Old Nov 2, 2004 | 03:37 PM
R.P.M.'s Avatar
Likes to swear....alot
well we are going to try pulling the cats off tonight and see if it makes any difference.
Old Nov 2, 2004 | 05:01 PM
If you have an 89 like it says in your profile then get a piece of wire and put one end of it into the single green test connector right near the battery and ground the other end. Here is a detailed procedure with what the codes mean. http://1300cc.com/howto/how2/codes.html
Old Nov 2, 2004 | 05:42 PM
R.P.M.'s Avatar
no sorry its a 87 we're working on we had the little led light setup on it but it showed no codes
86glxNA
Aug 18, 2015 03:33 PM
