Weber tuning help 13B 6 port
Old Nov 1, 2004 | 08:36 PM
hornbm's Avatar
FD > FB > FC
I have a weber 48 MM DCO (no choke) carb on my 86 13B 6 port. I have the ports wired open. My jetting is F11's with 180 mains, 160 air correctors 65f9 idle jets. Do not know the choke size.
The car ran a 15.6 at the track, but I know it can be much faster than that. Its running VERY rich, to the point where my bumper turns black, and I get about 14 MPG. The exhaust is so heavy it makes your eyes water if your standing by the car.
I fooled around with the jetting today, tried some new idle jets, 60F9's. They worked great!! Now I tried puting a 165 main jet in, and it made the top end just DIRT slow. The thing was really struggleing to get to redline in second. I put the 180's back in, and it flies up to redline again like normal, but the idle quality is much better.
Now im stumped ive tried 170 jets before and got similar results as the 165's. What should I do to quicken this thing up? I should be down into the 14's with this setup is there something Im over looking? It runs rich, but when I lean it out, it getts way slower! IM really stumped
Old Nov 2, 2004 | 09:36 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
this may or may not be of help.... i ran a SCCA GT3 12A bridgeport w a weber downdraft w mandated 38 mm choke tubes. made 259 hp between 7 and 10,000 rpm. my motors were built be roger mandeville and daryl drummond.
170 main gas 110 air corr F7 emulsion tube.
in 6 years i never changed anything but the gas jets and no more than 5 points each direction.
i tuned it by jetting for 1750 degrees on the egt in top gear. egt was 6 inches from port.
good luck,
howard coleman
Old Nov 9, 2004 | 07:53 PM
hornbm's Avatar
FD > FB > FC
Well those idle jets really did the trick. I just checked my gas milage today and it used to be about 13MPG, and now im getting 17!!!
Old Nov 10, 2004 | 10:12 AM
speedturn's Avatar
buy an inexpensive, less than $50 air/fuel ratio meter. It will speed up your carb tuning a lot if you know how your mixture is.
If you want to learn more about tuning carbs, then read this article I wrote 4 years ago, if you want to learn which jet affects which part of the rpm/throttle open angle :
http://www.mazspeed.com/carburetorfacts.htm
Skeese
65
Mar 28, 2017 03:30 PM
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
wallyrx7
Aug 20, 2015 05:55 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
