just got done fixing all fuel and oil leaks......for now.
Old Nov 1, 2004 | 03:25 PM
Jayseven's Avatar
Smile just got done fixing all fuel and oil leaks......for now.
2 weeks ago i noticed that i was leaking oil from my oil lines. They were both leaking right at the banjo fittings. so i called ray at malloy and bought new ones. Finally got them in the car. I drove it around for about a day or two and then started smelling fuel. My fpd (fuel pulsation dampener) was leaking..... so i had to order a new one of those. Just put it in the car today and drove it around. NO MORE LEAKS, for now at least. So now i just need to save some money, get it tuned and i will be able to sleep better at night.
Old Nov 1, 2004 | 04:10 PM
DaleClark's Avatar
RX-7 Bad Ass
Glad you got it whupped! Too many people put off those fixes and leaks, and that's what bites you in the butt. Especially gas leaks!
How many miles were on the parts that were replaced?
Dale
Old Nov 1, 2004 | 04:47 PM
Jayseven's Avatar
as far as i know they were the original parts. i know that the original fpd was black. The new one i got is dark green.
Jay
Old Nov 1, 2004 | 04:59 PM
Skeltah's Avatar
You wouldnt happen to have a picture of the leaks path down to the ground.. I have a oil leak that I am trying to track down.
Matthew Walsh
Old Nov 1, 2004 | 05:53 PM
Jayseven's Avatar
Matthew Walsh
na i dont, my oil lines were cracked right at the banjo fitings.
Old Nov 1, 2004 | 05:59 PM
akiratdk's Avatar
The Laser Man
I have Steel braided oil lines and they are leaking as well.... would teflon tape help this situation???? I'm assuming it would...
Old Nov 1, 2004 | 06:05 PM
DaleClark's Avatar
RX-7 Bad Ass
Teflon tape only helps with pipe fittings. The banjo bolts use crush washers to seal.
Dale
Th0m4s
Feb 26, 2019 02:04 AM
sYnth.
Aug 19, 2015 06:27 PM
tsmith94FD
Aug 16, 2015 05:41 PM
