Remote control to roll down windows
Old Oct 31, 2004 | 06:56 PM
GBone21's Avatar
Working on my 87 gxl, I have installed an alarm and want the power window module to roll down my windows when I press a button on the remote. Has anyone done this? The alarm is a crimeguard 745i4. Basically there are gonne be 4 wires to deal with. 2 per side. One wire will hook to the window motor and the other to the switch. The instructions I have are not clear. I could go into detail, but if someone has done this, I could ask a couple of specific questions. Any help would be appreciated.
Old Oct 31, 2004 | 07:42 PM
Icemark's Avatar
what are you having problems with???
You simply cut the wire going from the switch to the motor. Now you have a switch side and motor side. Wire in your window control moduals input and output wires to the switch and motor sides respectivly.
Old Nov 1, 2004 | 10:54 AM
GBone21's Avatar
Thanx Icemark, I was a little confused. So basically there are 2 wires going to the motor, the instructions say that I will only be cutting one, and then yes, I hook up one wire from the module to the motor side and the other to the switch side. Do you happen to know which wire will make it do down? It is a window roll up module but I imagine that I just hook it up to the down wire instead.? thanx. I don't do anything at the switch right?
Old Nov 1, 2004 | 11:59 AM
Icemark's Avatar
Old Nov 3, 2004 | 10:12 PM
GBone21's Avatar
thanx again Icemark
you the man
AXA
Sep 5, 2015 10:06 AM
