Knock sensor???
Old Oct 31, 2004 | 02:32 PM
DVSseven's Avatar
Knock sensor???
So yesterday evening we tried testing the knock sensor by tapping a breaker bar on the rotor housing right above where the knock sensor sits. While tapping on the block I held the rpm's at 2,000-2,500-and 3,000. Turned out that nothing happened while testing by tapping. There were no fluctuations in idle at all. Does this mean that the knock sensor is not working?
Old Oct 31, 2004 | 02:56 PM
So close to 12's!!!
I don't think it fluctuates the idle any, IIRC all the knock sensor does is detect knock and if its large enough it retards timing. You would probably have to hook a timing light up and verify that it backs timing off as you hit the housing.
Old Oct 31, 2004 | 03:07 PM
DVSseven's Avatar
Should it be checked with a voltmeter?
Does anyone have an easy way to check this with a voltmeter, because the manual only shows one place to put one of the testers, and not where to place the other....
Old Oct 31, 2004 | 05:13 PM
DVSseven's Avatar
knock sensor....
Does anyone have a system on how to test the knock sensor with the voltmeter? The manual only shows where to place one of the voltmeter probes and not the other....
rgordon1979
40
Mar 15, 2022 12:04 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
83revival
Sep 3, 2015 10:42 PM
