Replacing primary injectors on a RE?
Old Oct 29, 2004 | 06:03 PM
What have you guys done to use a bigger primary injector on a 13b-re motor? they have some type of special 550cc primaries, that take the place of the air bleed diffusers on the re motor, but the rew uses a side feet with a diffuser. Can i just swap to a fd fuel rail/ air bleed diffusers and upgrade from there, or is there a more custom approach?
Any conversions are welcome, like if a s4 fuel rail could be adapted as well, I have those laying around here.
thanks in advance
Old Oct 29, 2004 | 07:03 PM
R-magic's Avatar
I have a custom secondary fuel rail for the RE. If anyone is interested I can get some made up. PM with an email and i can send u pics of my setup.
Old Oct 29, 2004 | 07:33 PM
i have a couple top feed injectors already, i was mainly curious how to upgrade the primaries because they have some type of special tip on the side feed injector. would it work if i just used a fd primary fuel rail?
i want to run some fd 850 cc injectors for my primaries if i can rig it up
Old Nov 1, 2004 | 06:56 PM
any more ideas? can i swap a fd rail and secondary injectors onto it instead?
Old Nov 2, 2004 | 05:02 AM
The FD primary injectors look very similar to the RE primaries. Considering that 850s can be easily installed into the FD primaries, I expect that the RE engine can use 850s as the primaries.
The secondaries on the RE are different to the FD's.
That's about what I can remember.
Old Nov 2, 2004 | 05:09 PM
Marcel Burkett's Avatar
Got som extra 850's and primary rails .
Old Nov 2, 2004 | 10:51 PM
damnit! I just bought two 850's, how much do you want for an fd primary rail?
Old Nov 3, 2004 | 05:09 AM
88fc3sw/HX83's Avatar
You CAN use ANY FD primary fuel rail. I purchased a set from KGPARTS.com and it bolted in EASY! Hey VILA, how's my 2ndary fuel rail coming, can't wait to get it?
Old Nov 3, 2004 | 05:52 AM
rxrotary2_7's Avatar
Yep, I have primary and secondary rails ready to ship for RE motor if needed .
Old Nov 3, 2004 | 05:26 PM
how much are you asking just for an fd primary fuel rail?
Skeese
65
Mar 28, 2017 03:30 PM
