Autronic Forum Area is for discussing Autronic EMS
Autronic Autronic + Innovative Wideband
Old Oct 29, 2004 | 01:48 AM
artowar's Avatar
FD3SW211E55
[i]RICE RACING said (in a now closed thread):[\i]
Cant comment on the TEC product range.
The Autronic's only *bad* point is 0-1v range for WB EGA input, this used to be an issue untill Innovate Motorsports came along (read auto tuning).
You can get a special cable from them to go of the analog output of their meter (inexpensive) that solves all ground offset issues and scaling issues to be totaly comaptible with the Autronic SM2 Means you can auto tune without buying/renting and Autronic meter and do it very very cheaply.
I will be verifying this *myself* in a month or so once my new block is back together.
You can use the std CAS without mods on the V1.99chip, injector timing can be changed but I'm pretty sure not individualy thaough you can trim each injector on an individual basis.
Experiences: Very positive in my case, support used to be an issue but this has progressed laeps and bounds recently
Buying: If in America I recommend you pm Enzo250 of the forum ! Reasons, price is good and local support...
RICE RACING, I looked for the cable on Innovative's website, but I can't find it. I didn't see it mentioned in their forum either, at least not in connection with Autronic. There are a couple of threads with specs for a voltage divider, but no mention of anything that Innovative manufactures for this function. Did you have to special-order the cable?
Old Oct 29, 2004 | 04:27 AM
RICE RACING's Avatar
I cant comment on here, but if you PM me I can organize you a cable *to look at* hem hem, test etc hmm hmm wink wink
mulcryant
Oct 4, 2015 12:18 AM
