Leading coil problems
Old Dec 2, 2001 | 01:58 PM
takerwolf's Avatar
Its missing a lot and has new plugs and wires and it worked fine on the other car, also the resistance seems okay and I cleaned up all the contacts, any ideas? Maybe the engine to chasis ground?
Old Dec 2, 2001 | 03:38 PM
HAILERS's Avatar
HAILERS
Put it back on the other car and see if it still works good on the other car. Maybe its something you did on installation.
Old Dec 2, 2001 | 06:48 PM
takerwolf's Avatar
I don't think so because the original coil in the car did the same thing. Anyway, I can't put it back in the other car because the engine is removed and taken apart with no intent to put back together. (Its a salvage title and after finding out how much it would be for a rebuild kit and a rotor housing I changed my mind and would like to sell it for parts since I got the other one.)
Old Dec 2, 2001 | 06:51 PM
Scott 89t2's Avatar
SOLD THE RX-7!
how do you know the problem is the leading coil? if you switched them and the problem is still there then it's not the problem. the missing could be lots of things. too rich, plugs, cloged injectors...
Old Dec 3, 2001 | 12:17 PM
takerwolf's Avatar
I don't know that that is the problem, so I wanted to know what other things could be causing it, like maybe spark plugs not being grounded very well?
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
ZacMan
Sep 19, 2015 09:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
