What do you thing? manifold
Old Oct 23, 2004 | 08:12 PM
teachermechanic's Avatar
Hi, what do you thing i am not sure if the pipe size is ok?
Pipe size: 2"od and 1.880"id.
Also pic, the design like "OK"?
Old Oct 24, 2004 | 04:07 PM
manifold pic
Old Oct 24, 2004 | 06:47 PM
Evil Aviator's Avatar
Rotorhead
Collecteur d'admission ou d'echappement?
Orifice d'admission et cheval-vapeur?
Generalement la taille de la pipe 20B est identique que le 13B avec les memes cheval-vapeur par rotor.
Old Oct 24, 2004 | 06:59 PM
j9fd3s's Avatar
Community Builder
bon scott!
Old Oct 24, 2004 | 07:01 PM
Black13B's Avatar
In Full Autist Cosplay
c'est bon!
Old Oct 24, 2004 | 07:08 PM
Jeff20B's Avatar
Lapping = Fapping
Bon Marché!
Old Oct 24, 2004 | 08:15 PM
Rotorhead
I thank you all for your support. I don't feel quite as ignorant now.
Originally Posted by j9fd3s
bon scott!
Isn't that Australian?
http://www.homesong.info/bon.html
Old Oct 24, 2004 | 08:42 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
eiffel tower?
Old Oct 25, 2004 | 09:09 PM
now ?%$/"! pic
3 rotor pipe
Old Oct 25, 2004 | 09:13 PM
more
pipe 2
Old Oct 26, 2004 | 01:25 AM
SPiN Racing's Avatar
Should be ok... Hope its ported.
Looong RUnners. May have a smidge induced lag.
Also they are all not of the same length.. may create some interesting pulses.. then again they may be all proportioned in a manner that with the length looking to increase by the size of the shortest pipe each time it gets longer.. you may have lucked into sizing them properly.
I would have tried to make them all equal length to prevent reversion in the exhaust pipes that are in between power pulses.
AND... for you Evil
I am listening to my boy right now as I type... (2:24AM at work LOL)
Old Oct 26, 2004 | 09:09 PM
manifold
You know, i thing it's not possible to make manifold for 20B with the same lenght.
I try to make the best for the FD, but i know it's not perfect.
But my first question is you "know the right ID diameter"?
AND... for you Evil
Old Oct 27, 2004 | 04:49 AM
I would think that your 2" OD pipe would be appropriate, with the 1.8 ID.
The only time I feel you may need to do somethnig more extreme would be in cases where you were going for more extreme numbers in performance. The levels I dont believe 99 percent of the forum would be delving into.
For most all applications the ID of those pipes will keep the exhaust velocity at a proper level for nearly all applications, as far as I would figure.
As I said.. I feel they are a tad long.. but then again you may have space issues causing them to be that long.
I think that the shorter, and closer to equal length you can get the better.
Remember that the rotary has a portion of the combustion sysle still happening when the gasses exit the housing. You can either harness that expanding gas in the turbine of the turbo, or you can let it dissipate energy in the exhaust runners as heat.
Now.. as I said earlier.. you may have space limitations that require that design.. OR there may be things I didnt think of... (I am SURE there are plenty LOL) But I am sure it will work just fine either way. May or may not be the most efficient.. but that is for you to decide how much you want from the engine in the end.
Microtech
30
Apr 23, 2016 06:37 PM
Shainiac
Sep 3, 2015 10:08 AM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
