What settings should I use for my setup?
Old Oct 24, 2004 | 01:43 AM
SpeedKing's Avatar
Power Trippin'
Jeremy, take your car down to C2 Automotive in Oakland:
1009 7th St.
(510) 272-9869
They're alignment experts and work on FDs, and all manner of AutoX and race cars. Tell 'em what you want, and they'll set your suspension up for you.
Old Oct 25, 2004 | 08:47 PM
adam c's Avatar
Cheap Bastard
For me, I would run about 1.2 neg camber in front. The caster would be at 6 on both sides ideally, so you are close. Probably 0 toe in the rear. The rest looks OK to me.
Old Oct 25, 2004 | 11:56 PM
adam c's Avatar
Cheap Bastard
You are uninformed
You cannot have best tire wear and best handling at the same time. I choose to sacrifice some tire wear for better handling. If you choose to sacrifice some handling to get a little better tire wear, then you should have less negative camber in the front and rear. Maybe decrease to .75 negative for both.
If you are doing burnouts, then you really don't care about tire wear, and you shouldn't ask for help with alignment specs. Burnouts are a waste of gas and tires. They are hard on the tranny, rear end, and clutch. They are pointless, and can be very costly. I suggest that you TRY not to do them
Jun 26, 2016 10:21 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
