Wheel painting
Old Oct 19, 2004 | 05:35 PM
Section8's Avatar
Wheel painting
Hey guys, I just stumbled across a set of 93 stock wheels with used SO-2's for $100, gonna pick them up in a couple of weeks to use as track/autocross wheels.
I was thinking of painting them black, maybe using some of this stuff (found in search)
http://www.duplicolor.com/products/wheel.html
Anybody have any other suggestions? I'm hesitant to have them powdercoated since they'll be track only wheels and I don't really see the point in spending all that money on track wheels.
Old Oct 19, 2004 | 05:40 PM
BC-FD3S's Avatar
It cost about $50 bucks here in LA to powdercoat a wheel. I am not sure how many cans of spray paint you need to finish all 4 wheels. Plus you need to clean up and prime the wheel for a proper spray paint job.
BC
Old Oct 19, 2004 | 06:54 PM
Jayseven's Avatar
i just got done painting mine black. I used the same paint code on my car, brilliant black. and then i sprayed 2 coats of clear. They turned out great! I will post a pic as soon as i can get a hold of a camera. I am a trained painter, but if i were you and were just going to use them as track wheels i would just spray paint them and take the easy way out.
Old Oct 19, 2004 | 09:18 PM
Section8's Avatar
yeah, i'm not quite a trained painter, unless you count building models. I figured I'd try the stuff I linked above with some primer first and some clear after and that should be fine for what I'm going to do.
Old Oct 20, 2004 | 12:57 AM
JayShadow's Avatar
Super GReddy 7
I bought 3 cans of spray( i did many coats), and 2 cans of clear coat. Mines came out great. They shine really nice.
1. clean wheels
I used Steel wool )Sos pads will do). and a stainless steel brush.
2. Degrease Wheels
I used a can of engine degreaser.
3. Dry Wheel
With cloth. make sure to get all the faces of the wheel.
4. Spray.
I did 6 light coats. and 10 regular coats. (depends on how good you are with the spray).
5. Clear coat
Clear coat is the sealer. I had a nice shine Before the clear coat. When you First spray it, it will look white. Don't worry it will dry clear. Spray as many as you feel confortable doin.
Pics of my finished product.
Attached Thumbnails Wheel painting-41111283461_468_1.jpg   Wheel painting-41111283717_468_1.jpg   Wheel painting-41111283077_468_1.jpg   Wheel painting-41111283333_468_1.jpg
Old Oct 20, 2004 | 01:23 AM
ManGaZeRo's Avatar
Living the Dream
Anyone have a pic of silver fd with their rims painted black?
Old Oct 20, 2004 | 07:06 AM
Section8's Avatar
1. clean wheels
2. Degrease Wheels
3. Dry Wheel
4. Spray.
5. Clear coat
Thanks for the writeup, looks like your wheels turned out great! i see you did yours with the center caps still in place, do you know if the duplicolor paint above will work on the plastic caps?
Old Oct 20, 2004 | 08:43 AM
JayShadow's Avatar
Super GReddy 7
you shouldnt have a problem as long as the surface is dry and you spray enough coats.
Old Oct 20, 2004 | 08:58 AM
DamonB's Avatar
I have found that if you run Hawk HP+ pads and never clean the wheels that they stay a nice gunmetal color all by themselves When I do clean them people swear I bought new ones!
Old Oct 20, 2004 | 09:19 AM
Section8's Avatar
[IMG]https://www.rx7club.com/attachment.php?s=&postid=2312775[IMG]
Haha, yeah i've got HP+ pads on the front and man oh man do they dust like crazy!
Old Oct 20, 2004 | 08:49 PM
Jayseven's Avatar
when you paint the center caps. take them off and spray some adhesion promoter on them after you sand them. and then paint them seperate. you can get bull dog adhesion promoter at your local auto store. Thats what most people use when they paint plastics.
Old Oct 22, 2004 | 10:02 AM
Section8's Avatar
Excellent. Thanks again for the tip.
Old Oct 30, 2004 | 09:58 AM
Section8's Avatar
Damn it, I'm picking up these wheels next Saturday, and I can't find the black Duplicolor wheel paint anywhere, I can only find white, steel, graphite, bronze and clear. Anyone know where you can order this stuff online?
Old Nov 12, 2004 | 01:04 PM
Section8's Avatar
Damn it, I just got back from the auto store and I forgot this adhesion promoter. I do have some Krylon fusion black paint for plastics, think that will work?
Old Nov 12, 2004 | 02:55 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
I painted some bbs vert rims last weekend and they turned out awesome.
They do look better it person. Here is what I did to paint them. First clean them off really well. Next I just used 150 grit sandpaper to get the clearcoat off and then rinsed off the rims again. Dry the rims really well and then spray a nice coat of primer. Wait for the primer to fully dry and then mask what you need to. Then went over it with primer with the same 150 grit sandpaper to give it a rougher texture so the paint would stick easier. Wipe down the rim to make sure you get all the particles out. I used high gloss black duplicolor engine paint. I did two coats and then did 2 coats of clear. Came out pretty nice.
Old Nov 13, 2004 | 09:05 AM
Section8's Avatar
Since I had another thread about the wheels I posted pics in there too, but thought I'd post a pic of the finished product in here:
Old Nov 13, 2004 | 01:41 PM
Jayseven's Avatar
they look great man! Good job. I will post a pic of mine as soon as i can
cristoDathird
28
May 30, 2019 08:47 PM
