sway bar question
Old Oct 19, 2004 | 12:13 PM
Turbo2FC3S's Avatar
Touge FC3S
sway bar question
i've done a search on sway bars and found a lot of info on how having only ONE sway bar (either rear or front) will affect the car's handling. How will the car handle with both a rear and front sway bar? and which sway bars do you guys recommend for mountain driving?
Old Oct 19, 2004 | 12:31 PM
sunshine's Avatar
The TII has both front an rear anti-sway bars. If you stiffen the front, you induce understeer. If you stiffen the rear, you induce oversteer. For most ppl who do not know how to properly suspension tune, you should buy matched sets. Racing Beat, Suspension Techniques, Eibach, are some of the more popular brands.
Old Oct 19, 2004 | 06:12 PM
Black91n/a's Avatar
sunshine is wrong! He is thinking backwards, stiffening the front with a larger bar increases the load on the front tires, increasing understeer(push), a bigger rear bar will increase oversteer (tail wagging).
have a look at this:
http://www.sportcompactcarweb.com/pr...cc_projsilvia/
It's not immediately applicable to us, but it's shows the basics of how to tune an adjustable suspension to make it work properly.
The only adjustable (front and rear) anti roll bars that I've found are whiteline.
Old Oct 19, 2004 | 08:26 PM
RETed's Avatar
Actually the symantics is not quite right.
The bar resists weight transfer.
If a bar increases load (on front), that's implying there's more weight transfer (on front).
So, bigger front bar resists weight transfer to front, therefore, weight stays in back - weight in back induces understeer.
-Ted
Old Oct 19, 2004 | 09:50 PM
rynberg's Avatar
-Ted
WHAT?
An anti-roll bar has ZERO to do with weight transfer from the front to the rear. It "restricts weight transfer" from side to side because the loading must twist the bar before acting on the springs on each side. In effect, it acts to raise the spring rate in lateral loading on the car.
Making one end of the car stiffer, whether with springs, shock valving, or sway bar resistance, makes that end of the car slide first.
Old Oct 19, 2004 | 10:18 PM
DamonB's Avatar
Everything you ever wanted to know about sway bars
It's in the suspension and handling links sticky!
Sway bars do not change the amount of weight transfer as that is determined only by cg location compared to wheelbase and track width. Karts have completely solid suspensions and yet experience all of the differing weight transfers as a car with a sprung suspension. I could weld solid bars in place of the shocks on any car and that car would experience the same amounts of weight transfer as it did on springs.
Bars, springs and shocks have nothing to do with the amount of weight transfer a tire will experience.
Old Oct 20, 2004 | 03:37 AM
RETed's Avatar
Originally Posted by rynberg
WHAT?
Do I need to explicitly state that we're talking about cornering situations?
So you're telling me there is no such thing as weight transfer during cornering?
I didn't think I needed to state that the stabilizer bars do nothing while going straight...
-Ted
Old Oct 20, 2004 | 12:35 PM
rynberg's Avatar
-Ted
Please explain how a sway bar has any effect on weight transfer from the FRONT to the REAR of the car.
Old Oct 20, 2004 | 06:59 PM
Black91n/a's Avatar
Unless you have some funky "sway bars" going from the front to the rear tires (I've never seen this or heard of it being done) then sway bars will not affect front to back weight transfer.
Old Oct 20, 2004 | 08:52 PM
RETed's Avatar
Maybe "weight transfer" is not the correct term.
How about the front to rear "balance" while cornering?
-Ted
Old Oct 20, 2004 | 09:20 PM
DamonB's Avatar
Actually that's been done before in the past on some racecars. After that people tried plumbing the hydraulic dampers between the front and rear together. Once the third spring was invented there wasn't much use in either (even though the third spring is undamped in the majority of cases).
Old Oct 21, 2004 | 10:13 AM
rynberg's Avatar
-Ted
Well, of course sway bars affect handling balance, but they don't have anything to do with weight transfer front to rear....
Old Oct 21, 2004 | 11:22 AM
adam c's Avatar
Cheap Bastard
Perhaps ther is some confusion between traction bars, like you would find on a "drag car", and sway bars.
Or perhaps not
Old Oct 21, 2004 | 09:24 PM
RETed's Avatar
After thinking about this on a restless night...
How about this...
Cornering is a dynamic situation on which there are several factors that determine oversteer or understeer.
Most will assume "steady state cornering", which would eliminate a lot of these other variables, but I'm sure we all know this is not always the case.
Throttle lift-off, power oversteer, increasing / decreasing radius, etc. all will affect the steady state cornering, so this turns this whole scenario in a dynamic and changing environment.
Although it is not the sole responsibility of the stabilizer bars to dictate oversteer or understeer, there is some effect from them to inducing oversteer or understeer.
I agree, steady state cornering should not have anything to do with weight transfer front versus rear, but what about cornering that isn't?
You can argue about the stabilizer bars not being coupled, but if we look at the "big picture", the tire contact patch dictates traction of the vehicle, and they are all ultimately coupled with the vehicle's chassis.
-Ted
Old Oct 21, 2004 | 10:10 PM
DamonB's Avatar
^ you should run for public office
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Nosferatu
Sep 5, 2015 02:13 PM
