FWD wheels on a RWD car?
Old Oct 19, 2004 | 12:31 AM
Psycho3's Avatar
Wanted to buy rims.. found some I like but the specs on them say that they are for a FWD car.. does this matter at all and will they still fit? I have a 1987 RX7 Base model.
here are the rims in question.
Old Oct 19, 2004 | 01:26 AM
SpeedKing's Avatar
Power Trippin'
FWD, RWD, makes no damn difference. Bolt pattern looks universal. What's the offset and width(s)?
Old Oct 19, 2004 | 07:22 AM
DamonB's Avatar
Most likely the offset won't work. FWD and RWD use quite different offsets.
Old Oct 19, 2004 | 12:08 PM
adam c's Avatar
Cheap Bastard
It depends on the car and the wheels in question. Most RWD cars use different offsets than FWD. However, there are many exceptions. For example, the alloy wheels from the 81-85 rwd RX7 (excluding GSL-SE) were also used on the fwd Mazda 626.
You need to check the offsets to see if it will work.
Old Oct 19, 2004 | 01:07 PM
Psycho3's Avatar
it has a 40mm offset.. will this work?
Old Oct 19, 2004 | 06:06 PM
Black91n/a's Avatar
It depends on how wide it is, 16x7" 40mm is the stock TII size. Make sure the centrebore is big enough.
Old Oct 19, 2004 | 08:23 PM
RETed's Avatar
"FWD" versus "RWD" offsets is a marketing thing to help buyers figure out which wheel will fit.
Sorry to burst your bubbles, but the FC and FD use "FWD" offsets.
It doesn't really have anything to do with the strength or structure of the wheel - it's still cheap = weak.
-Ted
