MAP sensor/ haltech/ custom manifold
Old Oct 15, 2004 | 05:19 PM
gxlspeeder's Avatar
I'm planning on building a 13b pp with a haltech e6k and custom intake runners, intake plenum, and throttle bodies. I was just wondering where the MAP sensor would go.
Old Oct 16, 2004 | 07:12 PM
gxlspeeder's Avatar
bump
Old Oct 17, 2004 | 03:19 AM
drago86's Avatar
Im no expert, but i think you would have to run a vac line from each runner placed somewhere between the butterfly valves and the motor going into into a T fitting and then into the MAP sensor.
Old Oct 17, 2004 | 04:22 AM
Infini IV's Avatar
Microtech Tuning!
Could you just tap into either port runner? Reason I ask is because I've noticed very many people tune NA setup's with the TPS value instead of the MAP value...
Old Oct 17, 2004 | 11:05 AM
Crusader_9x's Avatar
you would want to tap the plenum after the throttle body. your gonan want a smooth yet acurate map reading and that would be the ideal spot.
Old Oct 17, 2004 | 01:33 PM
gxlspeeder's Avatar
I'm gonna draw up a picture to see where the best spot would be. thanks for the answers fellas.
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
befarrer
Sep 4, 2015 08:26 PM
