Best ignition at higher boost
Old Oct 15, 2004 | 11:34 AM
teamafx's Avatar
Im trying to see what ignition setup anyone with a higher boosting vehicle is using. I intend on running 25psi at the track and want to know what setup would be best to support it. any advice would be greatly appreciated! thanks
Old Oct 15, 2004 | 04:12 PM
Jeff20B's Avatar
Lapping = Fapping
RETed will say you need CDI, I'm guessing.
Old Oct 15, 2004 | 10:01 PM
Bond's Avatar
Im with reted then, cause i love my CDI.
Old Oct 16, 2004 | 07:28 AM
RXTASY1's Avatar
I have a Crane HI-6 on the leading coil and Nology Powercores on the trailing coils.
I have run as much as 23 PSI with this.
I have H20 injection also.
Old Oct 22, 2004 | 12:46 PM
Carl Byck's Avatar
Mad Man
I run 3- MSD6A, and stock coils in my FC. 10mm NGK wires, and 11.5 heat range NGK racing plugs. I have run 28psi for extended periods with no problems. Carl
Old Oct 23, 2004 | 02:14 PM
Mr. LV's Avatar
What kind of timing you usin'??
Old Oct 23, 2004 | 05:51 PM
RICE RACING's Avatar
Same run one Crane Hi6 CDI per leading plug in some cars, run around 26psi @ peak torque with lots of water injection (+very rich) and it fires like a champ !.
Good low cost solution and very durable, never had a problem with em
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
